» Site Navigation
» Other Sites
04-04-2008, 11:20 AM
#1 (permalink )
Vehicle: 560SEL, 190E, RX7
Front Wheel Bearings: A step by step pictorial
Ok, This is part I which includes the process of removing the break caliper out off the way, detach the hub from the brake disk and remove the bearings with their racers. Part II (When I get to it) will show how to pack the bearings with grease, how to slip in the bearing racers and finally how to assemble the whole thing with new brake components.
Cheers
Drew
04-04-2008, 11:22 AM
#2 (permalink )
Next
04-04-2008, 11:27 AM
#3 (permalink )
some more
04-04-2008, 11:29 AM
#4 (permalink )
and some more for PARTI
#5 (permalink )
END OF PART I
04-04-2008, 12:09 PM
#6 (permalink )
Ahhhh, there is a PART I A
The hub race seat looked like it had burrs from a previous/maybe mine too extraction. This job called for the Dremel
04-04-2008, 01:06 PM
#7 (permalink )
Racers
Ok, time to hammer in the racer. Notice I saved the old racer to take the hammer blow
while pushing the new ones in place. I will also be using grease that I use on my RX7 which is way better than most.
04-04-2008, 01:37 PM
#8 (permalink )
PART II
PART II: Grease Time
04-04-2008, 01:38 PM
#9 (permalink )
More grease and packing
04-04-2008, 03:04 PM
#10 (permalink )
Final Assembly
All I have left after this is to put new pads but to my horror I discovered that I had the wrong ones which came with the car in a box... Now I have to run to the dealership and get a set otherwise if I had more time I would have ordered them from Germanstar.
Anyway, enjoy!
Cheers
Drew
Linear Mode
