Old 03-29-2008, 07:38 PM   #1 (permalink)
Vehicle: 1991 190e 2.3, 1981 300D Euro, 1998 BMW 328i
1991 2.3 102 head removal questions
I am currently working to remove the cylinder head on my 2.3 to check for the leaks per my previous thread. Doing this for the first time, I must say that this is not an easy job. Many issues have developed along the way. From frozen bolts/nuts to stripped threads to connectors breaking during removal. Also the service manual is not as complete as it should be.
A few questions:
The manual indicates that the head be removed with the exhaust and intake manifolds attached. I appears to me that at least the exhaust manifold could be left in the vehicle and save the removal of the egr, dip stick, and O2 sensor, and the additional weight of the lifting it out. Why is it recommended this way?
I don't have a gantry crane to lift the cylinder head off the block.
If anybody had done this job before I would be interested in any shortcuts.
Thanks, JM
jmas2k is offline   Reply With Quote
Old 06-19-2008, 12:42 PM   #2 (permalink)
jdjones2001's Avatar
Date registered: Jan 2008
Vehicle: 1993 190e 2.3
I left my exhaust mani and all that goes with it in the car when I took mine off.
BAM
jdjones2001 is offline   Reply With Quote
Old 06-19-2008, 03:02 PM   #3 (permalink)
Date registered: Jul 2007
Vehicle: 1987 BMW 325is M-tech I German Spec + 1985 Mercedes-Benz 190e 2.3 Manual
I Just took mine off.
I removed the intake manifold and and I wanted to remove the exhaust manifold as well.
But like you said it's difficult with frozen bolts and such.
Anyways I was able to get the head off with the exhaust manifold attached. I removed the bolts from the Y pipe ( 4 of them)
The most difficult time I had was removing those pressed pins for the timing cover.
Cheers and good luck.
Ben
Cacciatore08 is offline   Reply With Quote
cab removal/ head removal/ hydraulic install/ esde Unimog 12 11-08-2006 05:21 AM
102.985 or 102.983?? alexdelmore W201 190E, D-Class 5 10-11-2006 01:44 PM
W124 1991 300D 2.5 T - need new/rebuilt cyl head trangen W124 E,CE,D,TD Class 0 07-22-2005 10:19 PM
1991 2,5-16 (RÜF 150kW)-- (Cylinder head cover) Murat W201 190E, D-Class 0 07-12-2003 03:02 AM
1991 350SD new head unit Guest (MBNZ) Audio & Telematics Forum 0 06-04-2001 03:35 PM
