» Site Navigation
» Other Sites
Old 04-23-2008, 05:56 AM   #231 (permalink)
lomtevas's Avatar
Date registered: Nov 2006
Vehicle: 1986 190E 2.3-16, 1992 190E 2.3 and 2007 GL450
Send a message via Skype™ to lomtevas
Day Two of Bodywork
Tuesday, the shop rolled out the hood.
All scratches are gone and the major dent and the minor dings are gone.
lomtevas is offline   Reply With Quote
Old 04-23-2008, 02:03 PM   #232 (permalink)
lomtevas's Avatar
Wednesday - A Day of Rest
The car rested today.
The underbody will be cleaned and in places the undercoat will be removed and reapplied. Metal will be cleaned and where necessary wire brushed.
Preparing a final parts order for some clips, window trim and two door seals.
Old 04-24-2008, 01:09 PM   #233 (permalink)
lomtevas's Avatar
Thursday a Day of Rest
Ordered new trunk badges from Helms Brothers. The 190E badge no longer comes in the pin attached variety. Now, it's the adhesive variety. The dash is available as a separate purchase. A new trunk star and mounting grommets will adorn the trunk lid.
Old 04-25-2008, 12:47 PM   #234 (permalink)
lomtevas's Avatar
Friday - Starboard Front Door
Today was the finishing up of straightening the rear starboard quarter panel with primer and the rolling out of the starboard front door's sheet metal. It was dinged heavily.
The starboard rear door was finished and reveals as thin a layer of putty/sealer on top of primer as possible. The paper mask shows the point where new paint will not go down below the cladding line.
The dings in the front door required a grinding down of nearly all previous paint and the application of primer and then putty/sealer. That sealer is thickly applied and drying. It will be sanded down to just barely a thin layer from the rear of the door toward the front.
Old 04-25-2008, 01:01 PM   #235 (permalink)
lomtevas's Avatar
Deen
I have known Deen since 2000. His work is excellent because he puts his heart into his work. He is so good with paint that he can make a pimped out ride in any color combination and pin striping wanted. He can also paint a car true to its original color. He takes wrecked late model Benzes and restores them for his customers. Paul at Helms Brothers knows of Deen's work.
As for the 16v, he will make the car appear as closely as possible to the original factory model. He did say and I did not stop him from saying that he would add perhaps a touch of Ferrari gloss by the sanding of intermediate coats as long as the 16v paint does not take on the appearance of a Ferrari finish.
He said that Speis Hecker will definitely look like a Mercedes from 1986 despite the fact that the original maker of the paint, Glasurit (not the BASF brand), is long out of business and Speis Hecker provides todays paint to Mercedes.
So, it's a 2008 version of a 1986 finish.
Old 04-29-2008, 11:23 AM   #236 (permalink)
lomtevas's Avatar
Saturday through Tuesday - Starboard Side Done
The starboard side is complete as of the second Tuesday in the body shop.
Old 04-29-2008, 01:15 PM   #237 (permalink)
lomtevas's Avatar
2.3-16 Body Panels
This shot from the starboard front demonstrates the effort at replicating the factory's straightness of body panels. Each panel has to be as straight and clean as possible and when all are put together, they all line up correctly.
The sealer/filler/primer combination is intended to match the thickness of primer material laid down at the factory. This will prevent the chips and nicks on door edges.
The paint will slightly "pop" in bright sunlight.
Old 04-29-2008, 02:27 PM   #238 (permalink)
Ivan820's Avatar
Date registered: Jan 2008
Vehicle: 1990 190E 1.8
...you're my new hero
... i mean wow, it was already brand new when u bought it
Ivan820 is offline   Reply With Quote
Old 04-29-2008, 02:32 PM   #239 (permalink)
MTI
MTI's Avatar
Vehicle: '85 190E 2.3 '85 2.3-16 '99 C280
I may be a bit "thick" at times, but I honestly don't understand that statement. In all the prior photos, the doors and fenders appear to have been left on the chassis during the prep work and then during the primer coats. Were they previously removed?
MTI is offline   Reply With Quote
Old 04-29-2008, 04:03 PM   #240 (permalink)
Date registered: Jun 2007
With all the boat terminology I fully expect you to remove the driver’s seat and install a captain’s chair. Looks like your project is progressing well and we are looking forward to the final result.
bgandy is offline   Reply With Quote
8,000 mile 240D vwbuge W123 E,CE,D,CD,TD,TE Class 11 06-29-2006 03:31 PM
75,000 mile service pize98 W163 M-Class 8 03-15-2005 09:25 PM
75,000 mile or 120,000 kilo Service- How costly? Dohockey W124 E,CE,D,TD Class 5 02-21-2005 03:41 PM
70,000 Mile Service... Rastafarian W163 M-Class 9 07-22-2004 10:07 AM
90,000 Mile Service jcochrane007 W124 E,CE,D,TD Class 1 04-28-2004 02:01 PM
