Old 04-16-2008, 08:16 AM   #201 (permalink)
Date registered: Mar 2008
Rear spoiler again
Judging by the reflection on your spoiler, the surface is no longer flat. Are you going get it replaced / repaired? Once fixed can you post the 'before & after' pics? Thx a lot.
jorijori is offline   Reply With Quote
Old 04-16-2008, 08:37 AM   #202 (permalink)
ducatipaso's Avatar
Date registered: Jul 2006
Vehicle: 1985 280TE, 1993 190E 2.6 5-gang + various other stuff
huh? isnt it supposed to be turned up a bit on the trailing edge?
<table width="600" border="1" bordercolor="black" cellpadding="10" cellspacing="0" bgcolor="white">
<tr>
<td><img src="http://roten.smugmug.com/photos/229720447-O.jpg"></td>
<td align="right" nowrap><b>
<a href="http://190e.mine.nu">93 190e 2.6</a>
<a href="http://318ic.mine.nu">92 318ic</a>
<a href="http://ducatipaso.org">88 750 paso</a>
<a href="http://280te.mine.nu">85 280te</a>
83 r80/7
</tr></table>
ducatipaso is offline   Reply With Quote
Old 04-16-2008, 10:19 AM   #203 (permalink)
lomtevas's Avatar
Date registered: Nov 2006
Vehicle: 1986 190E 2.3-16, 1992 190E 2.3 and 2007 GL450
Send a message via Skype™ to lomtevas
The surface of the spoiler has micro-ripples on its surface because it is not made of a solid material as I thought it was, but rather it is made of a soft plastic covered in a very flexible paint.
Whatever happens to it, I'll be glad to post before/after photos.
lomtevas is offline   Reply With Quote
Old 04-16-2008, 10:25 AM   #204 (permalink)
lomtevas's Avatar
2.3-16 Brake Rotors
Here is the verdict on the rotors.
The 22 year span of the contact between the factory rotors and the factory pads caused both to fuse in a rusted clump.
The results are rotors with ruts. All four are now replaced and the brakes work smoothly and quickly. There is new brake fluid as well.
It appears that the rotors in the rear were chipping and grinding at their pads which resulted in a chirping sound: as if the rear suspension was creeking.
Replacing the rotors and pads eliminated that sound.
The cooling system hardward Dorgler says are in proper operating condition and there is no need to change the alternator.
Paint possibly Friday.
Old 04-16-2008, 07:03 PM   #205 (permalink)
lomtevas's Avatar
Road trials.
It seems the car acts as if it is completely ready to resume ordinary driving on any terrain in any weather conditions. The temperature gauge likes to sweep between roughly 85c and 100c. Moving forward rather quickly drops the temperature back to 85c and waiting in stopped traffic rather quickly raises the temperature to 100c.
This rather quick rise and fall is markedly different from the 8v. The 8v sweeps very, very slowly up and down.
There are times when the motor revs to 900rpm and then it goes to roughly 800rpm. Acceleration is never rumbly; instead, it is snappy and light.
Old 04-16-2008, 10:16 PM   #206 (permalink)
MTI
MTI's Avatar
Vehicle: '85 190E 2.3 '85 2.3-16 '99 C280
Yes, it is. The wing profile is not flat.
When driving the 16 valve, keep in mind that "life begins" at around 4K rpm.
MTI is online now   Reply With Quote
Old 04-17-2008, 05:52 PM   #207 (permalink)
lomtevas's Avatar
I had it on the Belt Parkway tonight.
Tomorrow paint.
Old 04-17-2008, 10:25 PM   #208 (permalink)
wheels
I think your car is gonna look so hot with EVOII wheels painted gun metal / titanium. Shiny black paint with matte gun metal rims is definitely one of a kind...yet it is still original like you wanted.
Old 04-18-2008, 09:10 AM   #209 (permalink)
lomtevas's Avatar
Maybe in the future I'll get my hands on an EVO car, but for now, bodywork begins.
Prestige is canceled.
I went back to my traditional shop for the 199 paint.
Old 04-18-2008, 09:21 AM   #210 (permalink)
lomtevas's Avatar
Body Restoration of the 8,000 mile 190E 2.3-16
Body restoration began today with a strip of the car.
The rear was stripped of its parts. The rear badging was removed by allowing the heat of the sun to loosen the badge adhesive/tape.
Interior trim is being removed so as to protect it from the paint booth environment. The plan is to seal off all interior surfaces to avoid spray residue.
You can see the new 70 litre fuel tank mounted in the trunk.
Parts are being safeguarded and will be cleaned for reinstallation.
Speis Hecker code 199 is being ordered today. One gallon for precoats and one gallon for top coats. Wet sanding and foam wheel polishing is the restoration method: to simulate factory original appearance. A parts inventory will take place and appropriate part orders will occur at Helms Brothers.
Currently, the original hood is planned for restoration, not a replacement hood I bought two months ago.
8,000 mile 240D vwbuge W123 E,CE,D,CD,TD,TE Class 11 06-29-2006 03:31 PM
75,000 mile service pize98 W163 M-Class 8 03-15-2005 09:25 PM
75,000 mile or 120,000 kilo Service- How costly? Dohockey W124 E,CE,D,TD Class 5 02-21-2005 03:41 PM
70,000 Mile Service... Rastafarian W163 M-Class 9 07-22-2004 10:07 AM
90,000 Mile Service jcochrane007 W124 E,CE,D,TD Class 1 04-28-2004 02:01 PM
