Old 04-14-2008, 10:55 AM   #191 (permalink)
lomtevas's Avatar
Date registered: Nov 2006
Vehicle: 1986 190E 2.3-16, 1992 190E 2.3 and 2007 GL450
Send a message via Skype™ to lomtevas
It's back to Dorgler. The car has a failed clutch slave cylinder. A new one is on the way. Also, all rotors and pads are going. I am also investigating a new radiator and water pump.
Paint is on hold a few days.
I will thoroughly road test the car to allow any other failure to occur. Once those kinks are worked out, then we'll paint with 199. Otherwise, I'll have a beautifully repainted 16v and then get splotches, grease and scratches/nicks on the new paint from other minor repairs.
lomtevas is offline   Reply With Quote
Old 04-14-2008, 12:53 PM   #192 (permalink)
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280
Originally Posted by lomtevas View Post
The 16v puts out quite a racket. The clatter is noisy and the car is way more mechanical in feel and sound than the 8v.
You say that as if it were a bad thing.
On the other hand, if what you're hearing from the engine is anything but a harmonious mechanical exercise . . . something is wrong.
MTI is offline   Reply With Quote
Old 04-14-2008, 01:05 PM   #193 (permalink)
lomtevas's Avatar
Sorry. I did not imply that taking the 16v back to Dorgler was a bad thing. It is a very good thing. We have a 22 year old vehicle that appeared on the scene in its original form. Even its brake fluid was original. Many parts had to go because the objective was to restore the car to full roadability, not just museum visibility. Two of those parts are the slave and the brake hardware. Also, Dorgler will find the creeking sound in the rear.
These failures are anticipated and sought after. I test the car in a real world environment. Something is supposed to fail and when it does, it gets replaced and repaired.
I also apologize for coming on a bit too strong about the motor. It is way more mechanical sounding than my 8v and my GL450. The 8v has a bit of a throaty sound and the GL450 you can hardly hear running. The 16v is nearly identical to the twin cam 280 six cylinder motors of the 70's. It's "mechanical" and the exhaust is turned up to sound like a baritone cricket.
In the end, the 16v is coming along and the list of repairs remains at clutch slave cylinder, blower, antenna, rear suspension creek, rotors and pads, radiator and water pump.
Thank you for your observation.
Old 04-14-2008, 06:23 PM   #194 (permalink)
Date registered: Jun 2007
I'm just wondering, with as many issues that you have revealed in this thread, if there is some association that you can report abused vehicles to. The PO, although you explained his demise, probably died from the same neglect that this car has had. Perhaps his family/relatives gave the care to him in the same manner as the car. JMO
bgandy is offline   Reply With Quote
Old 04-14-2008, 07:20 PM   #195 (permalink)
lomtevas's Avatar
Sort of like a Society for the Prevention of Cruelty to Cars?
That would be tough. How do you tell if a person abused a car or mother nature abused it?
As to all the issues I reported here, remember that I said initially I would be brutally honest. I am detailing everything - perhaps to the exclusion of the tiniest clips and bolts.
This means that I do not hold responsible the previous owners because their standards of car maintenance likely do not approach mine.
I went to night classes in an auto school in Germany and our car of choice was the Mercedes. So I catch the smallest failures and fix them on the spot. That's why my 8v is still with me.
There will always be issues because I will use the car as if it is fully roadworthy and the intent is for every gremlin to reveal itself to be repaired and restored.
It is a museum piece of living automotive history and it happened by the right owner who will care for it the way it deserves to be treated.
Its faulty slave was removed today and a new one is on its way.
Old 04-15-2008, 12:37 AM   #196 (permalink)
Date registered: Mar 2008
Pic request
Hi Lomtevas,
Can yout take a close up picture of the surface of your rear spoiler? TIA.
jorijori is offline   Reply With Quote
Old 04-15-2008, 05:13 AM   #197 (permalink)
lomtevas's Avatar
Originally Posted by jorijori View Post
Hi Lomtevas,
Here are three views.
Old 04-15-2008, 12:17 PM   #198 (permalink)
lomtevas's Avatar
The seals in the slave cylinder failed to hold clutch fluid pressure after 22 years of atrophy.
A new slave cylinder is now installed in the car and the clutch works normally.
The car awaits a shipment of brake rotors and pads (and sensors).
Dorgler says that no new cooling system parts are needed. The waterpump and radiator are new and the coolant appears to be clean. Dorgler will check the alternator and will check the power steering system to see if either component is not operational under ordinary driving loads.
Paint may be as early as Friday but we'll see.
Old 04-15-2008, 12:23 PM   #199 (permalink)
1987190E2.6's Avatar
Date registered: Nov 2007
Vehicle: 1987 Mercedes-Benz 190E 2.6
So what are your plans for this car? Is it going to be put in storage and taken out on weekends? Judging by some of the things you said earlier, I don't think you'll make it an everyday car.
1987190E2.6 is offline   Reply With Quote
Old 04-15-2008, 03:00 PM   #200 (permalink)
lomtevas's Avatar
The goal is to maintain this piece of automotive history in substantially new condition. So, I'll be using it on weekends and taking it to shows. It will be an ongoing work in progress to keep it clean and fully operational.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
8,000 mile 240D vwbuge W123 E,CE,D,CD,TD,TE Class 11 06-29-2006 03:31 PM
75,000 mile service pize98 W163 M-Class 8 03-15-2005 09:25 PM
75,000 mile or 120,000 kilo Service- How costly? Dohockey W124 E,CE,D,TD Class 5 02-21-2005 03:41 PM
70,000 Mile Service... Rastafarian W163 M-Class 9 07-22-2004 10:07 AM
90,000 Mile Service jcochrane007 W124 E,CE,D,TD Class 1 04-28-2004 02:01 PM
