» Site Navigation
» Other Sites
Old 03-27-2008, 04:55 PM   #41 (permalink)
AMGViper's Avatar
Date registered: Sep 2006
Would like to point out that removing these bolts requires a long 5mm hex key, not the 1/4 socket as the first post in the thread says. Thanks for the help, I didn't think it would be this difficult (day 2) while trying to remove it.
AMGViper is offline   Reply With Quote
Old 03-29-2008, 10:25 PM   #42 (permalink)
HATTENATOR's Avatar
Date registered: Jan 2008
Vehicle: 1988 190E 2.3
the picture in the post shows the hex bolts I will clear up the post but I use a 1/4 rachet and a 5mm hex socket to this.
Why dream of just any vehicle, when you can dream of owning one that was never imported.
HATTENATOR is offline   Reply With Quote
Old 05-14-2008, 06:20 PM   #43 (permalink)
Date registered: Mar 2008
I have a '87 190d and was just looking for the torque values for the 6 bolts on the transmission pan. However, after reading through this thread, I'm blown away by the knowledge and helpfulness here so I have a few other questions regarding my transmission. I recently replaced the tranny pan gasket and filter because it had a slight leak that bugged me. I bought aftermarket and put it back together (bad idea). It still had a slight leak and I got tired of it so I just went under and tightened the bolts down. Real Bad Idea! That same day while backing my car in the garage, I got a huge puddle of tranny fluid under it. Luckily (I'm hoping) it happened in my driveway so it shouldn't have hurt the tranny. After removing the pan again, I noticed the aftermarket gasket had split halfway down the side. Well, this time I went to the stealership and got the MB gasket. I asked them if they had the torque specs for the bolts and they said no. I have the info on my computer which crashed big time the same day(and still dead). I believe it was around 14nkwm if I remember correctly????
Also, my 190d shifts into reverse fine sometimes and other times it kind of stalls first and then shifts hard into reverse. It shifts fine into all the other gears. Any thoughts???
Thanks
zorro007 is offline   Reply With Quote
Old 05-15-2008, 12:23 AM   #44 (permalink)
Date registered: May 2008
I have a 190e 2.3-16. When the automatic transmission goes to the final/4th gear, the engine will just rev. But if i put the gear lever back to 3rd, the power is delivered. Just wondering which part of the automatic transmission you guys think is the culprit? Clutch K2? Car is 1987.
1tt1 is offline   Reply With Quote
Old 05-16-2008, 07:56 PM   #45 (permalink)
FYI...my computer is back up. For anyone interested, torque on the tranny pan bolts is 7nm.
Old 05-19-2008, 09:49 PM   #46 (permalink)
HATTENATOR's Avatar
Zorro
Here is the most common problem for harsh shifts into reverse only
Old 05-19-2008, 09:55 PM   #47 (permalink)
HATTENATOR's Avatar
1tt1
I would recommend having that looked at by a mercedes trans tech but it sounds like a K2 clutch plate issue or a valve body issue.
Old 06-12-2008, 05:48 PM   #48 (permalink)
Vehicle: 1985 190E 16v <p>1983 turbo diesel 300d = sold
Send a message via AIM to brax
anyone have issues with while cruise'n in 4th at steady throttle, flat road, tran'z decides it wants to shift to 3rd and stay ? it i nail it and down shift it will proceed to shift back to 4th, otherwise sticks, thanks
brax is offline   Reply With Quote
Old 06-28-2008, 05:50 PM   #49 (permalink)
Date registered: Jun 2008
Vehicle: 280GE,190E,230TE
I am new at benz world but your information about 722.4 automatic transmission is very very helpfully for me,
I have one old 1988 190E AMG and have problem with my transmission, when saw all information you put here only said WOW amazing, thanks for your help ,now I change the modulator and buy the pressure indicator for test the pressure.I follow the test sugested and sure I have good succes.!!!
itamar Chavez Cerda is offline   Reply With Quote
Old 08-03-2008, 05:46 AM   #50 (permalink)
Date registered: Aug 2008
HATTENATOR your my new hero , in about 5 minutes from googleing i'm reading the manual of how to fix my gearbox.
Anyway thanks a million , i'm going to do this gearbox for sure now , i'm a marine mechanic so never had a need to pull apart an auto , that manual made it look easy , famous last words.
Cheers Andrew.
Andrew.H is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
haighworld
replace rear subframe mounts - DIY or not DIY? philthompson W126 S,SE,SEC,SEL,SD,SDL Class 1 02-02-2007 06:40 AM
Replace Modulator Valve in the Transmission ???? MBUSER W201 190E, D-Class 0 12-22-2005 06:07 PM
Transmission Modulator Mike Z W123 E,CE,D,CD,TD,TE Class 1 10-01-2004 04:48 PM
Common Transmission Shifting Problems fastneutron W202 C36 AMG, C43 AMG 3 06-24-2003 08:00 PM
Transmission modulator Jnathan Laws W126 S,SE,SEC,SEL,SD,SDL Class 5 05-12-2003 12:31 PM
