Old 02-12-2008, 04:51 PM   #11 (permalink)
Date registered: Jan 2006
Vehicle: 1992 2.3 190E
Very detailed rebuild links, especially the last one. Shift complaints in just about any combination you can think of and the remedy. Except, the number one complaint is the hard shift 1st to 2nd with actually is not addressed other the All shifts being harsh it's vacuum and or modulator adjustment.
Still don't see the Thread of the test port :-( , but one thing I was wondering about to save time is one click on the Adjusting Pin is approx .4 bar which would help get in the game sooner.
Thanks
Dan
Logon_Bob is online now   Reply With Quote
Old 02-12-2008, 06:40 PM   #12 (permalink)
HATTENATOR's Avatar
Date registered: Jan 2008
Vehicle: 1988 190E 2.3
just pop the test port bolt out and check the bolt threads and diameter any good hardware or automotive place that sells metric bolt should a thread pitch guage. then you will know and it shouldnt be too hard to get that bolt out.
Have you checked your vac lines yet going to the modulator. if you pull the line off a modulator and then drive it you get that hard shift from first to second you are talking about. I would check the line if you havent
Why dream of just any vehicle, when you can dream of owning one that was never imported.
HATTENATOR is offline   Reply With Quote
Old 02-12-2008, 07:15 PM   #13 (permalink)
I have calipers and a thread gauge but yes that works. Hard shift is not my problem, but yes I am aware of that test. My 1st to 2nd is gorgeous as is 3rd to 4th.
Keep up the good work.
Dan
Old 02-12-2008, 11:53 PM   #14 (permalink)
HATTENATOR's Avatar
is it a flair in the second to 3rd shift if so it will probably be the K1
Old 02-13-2008, 12:30 AM   #15 (permalink)
w201 Über Moderator
Kynyption's Avatar
Vehicle: 1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
Send a message via ICQ to Kynyption Send a message via AIM to Kynyption Send a message via MSN to Kynyption Send a message via Yahoo to Kynyption Send a message via Skype™ to Kynyption
Copied to FAQ. Informative post.
You Can Find Me In The w201...
...Don't Forget to Add Yourself To The w201 Frappr map!...
...Coming soon Projekt Euro
Kynyption is offline   Reply With Quote
Old 02-13-2008, 12:37 AM   #16 (permalink)
HATTENATOR's Avatar
thanks kynyption
Old 02-13-2008, 12:57 AM   #17 (permalink)
HATTENATOR's Avatar
Dan does this sound like yours
This link goes to a detailed pictured walkthrough of this proceedurehttp://www.benzworld.org/forums/w201...t-install.html
The K1 Kit Page
2/3 Upshift Flare Repair
This is a fix for transmission slip/flare on 2-3 upshift at partial load for 722.3,722.4 and 722.5 automatic transmission
If your automatic transmission shifts fine with the exception of a flare on the shift up from 2nd to 3rd, and you've exhausted all your adjustment options, then the K1 Accumulator Spring Kit might be the solution.
The spring kit (part number 126 270 44 77) will cost you less than $10, and is a drop in replacement for the K1 accumulator's spring/piston assembly in your transmission's valve body. While you're buying parts, you will also need several quarts of transmission fluid and a new gasket for the pan. You might as well change the filter while you are in there too.
Before you begin. Get some old newspapers/cardboard underneath the transmission. Fluid will be constantly dripping while the transmission pan is off.
Begin by draining the transmission fluid. On my W126, I also had to remove the front crossmenber (by undoing 3 bolts on either side) to get the necessary clearance to unscrew the K1 accumulator cover. NOTE: MB recommends replacing these bolts. You may want to support the crossmember with a small jack to avoid it clattering to the ground.
Once the fluid's drained, unbolt and remove the transmission pan. Again, you might want to use a small jack to support it. Also, bear in mind there will probably still be fluid in the pan.
Locate the front of the valve body. You will be unscrewing 4 screws and removing a rectangular cover.
NOTE: The four screws for the cover are very tight. I ended up using a 1/4 inch driver with a flat-headed socket to unscrew them.
This was especially useful for the top screws, since the curve of the torque converter housing made it difficult to turn a screwdriver.
Pull out the spring/piston assembly from the valvebody. It'll look something like this.
Go ahead and pull the spring assembly out from the tube. You'll notice that there is also a small spring left at the bottom of the tube. Remove that too.
Put the old springs aside and open up your new parts. First of all, drop the new small spring into your old tube.
Next, loosely assemble the rest of the pieces from the kit (2 springs, 2 plastic rods) like so. NOTE: It may not be obvious from the picture, but the smaller spring goes on the white rod, and they are then inserted into one end of the big spring.
Now the fun part. You're going to have to squash that loose assembly of springs and plastic rods together. Carefully. The white rod will fit into the black, but it does take a fair bit of pressure to do this. Once the 'head' of the white rod is in all the way, the entire assembly will hold itself together (just like the old one does). Just be careful and take your time. Remember, your dealing with springs under pressure, and parts can go flying if you're not careful (don't ask me how I know).
Before putting everything together, make sure everything is nice and clean. When you're ready, drop your new spring assembly into the tube like so.
Now put the entire assembly back into the valve body, and screw the cover back on, nice and tight.
From this point on you are effectively following the same procedure as a transmission fluid/filter change. If you are also replacing your transmission filter, now's a good time to do so. Put your new seal on the transmission pan, and bolt it back up (don't overtighten it either). If applicable, bolt your front crossmember back on, and fill up the transmission, being careful not to overfill it. NOTE: The transmission dipstick under-reads when the transmission is cold.
Before going for a test drive, start the car up, and with the brake on, run the gear selector up and down the gate, pausing a few seconds at each position, so the gear engages/disengages, and the fresh transmission fluid gets a chance to circulate properly.
Hopefully, you should notice an improvement in the 2-3 flare. You may find that you have to make some adjustments, since it's possible that the transmission was previously adjustated to try and compensate for the flare.
Old 02-13-2008, 01:17 AM   #18 (permalink)
w201 Über Moderator
Kynyption's Avatar
Don't thank me bro. Thank yourself for posting helpful information for other users.
Old 02-13-2008, 02:51 AM   #19 (permalink)
Date registered: Nov 2006
Woah this is exactly why I logged on today. Too weird it was the first post and I didn't have to search for info. Anyway thanks a bunch for posting all this I'll take it as a sign I need to swap my modulator asap
thanks again
1986 16v
1993 2.3 amg
190ed is offline   Reply With Quote
Old 02-13-2008, 03:45 AM   #20 (permalink)
HATTENATOR's Avatar
190ED
you are very welcomed and I am glad I could help and I hope it helps alot of people with tranny problems. what problems were you having with your 190
replace rear subframe mounts - DIY or not DIY? philthompson W126 S,SE,SEC,SEL,SD,SDL Class 1 02-02-2007 06:40 AM
Replace Modulator Valve in the Transmission ???? MBUSER W201 190E, D-Class 0 12-22-2005 06:07 PM
Transmission Modulator Mike Z W123 E,CE,D,CD,TD,TE Class 1 10-01-2004 04:48 PM
Common Transmission Shifting Problems fastneutron W202 C36 AMG, C43 AMG 3 06-24-2003 08:00 PM
Transmission modulator Jnathan Laws W126 S,SE,SEC,SEL,SD,SDL Class 5 05-12-2003 12:31 PM
