Old 12-28-2007, 07:31 PM   #1 (permalink)
Date registered: Dec 2007
Post 190E hesitation problem
Have a 93 190E and am having a problem. Can anyone help?
If I drive my car and gradually accelerate the car runs fine,but any time I push the pedal to the floor such as when I am passing the car does not accelerate just kind of sits at the speed it is at. If I leave off the throttle and feather the gas pedal down slowly the car will accelerate. this happens at any speed. Incidently the motor in this car is a 2.3L. Could it be the mass air flow sensor??/
mkruth is offline   Reply With Quote
Old 12-28-2007, 07:50 PM   #2 (permalink)
E=MBČ
GermanStar's Avatar
Vehicle: GermanStar.net
I'm thinking that it probably isn't the mass air flow sensor, since the car does not have one. In any case, I'll slide this down to the w201 section for you.
German Star
GermanStar is offline   Reply With Quote
Old 12-29-2007, 06:07 AM   #3 (permalink)
lomtevas's Avatar
Date registered: Nov 2006
Vehicle: 1986 190E 2.3-16, 1992 190E 2.3 and 2007 GL450
Send a message via Skype™ to lomtevas
Originally Posted by mkruth View Post
Have a 93 190E and am having a problem. Can anyone help? Incidently the motor in this car is a 2.3L. Could it be the mass air flow sensor??/
The 2.3, 2.6 and 300E series all had an airflow meter mounted next to the fuel distributor.
Without more detail about the car, you may have one problem or a mixture of problems. How many owners prior to you? Mileage? Accidents? Aftermarket garbage installed? Overheating? Occurs only when A/C/ is on? We need the history.
For example, some owners tear apart their motor and don't know what they're doing. There are alignment marks cast into the motor that must be lined up when reassembling. Being off one notch can affect timing. Your acceleration problem can be traced to bad timing.
If the car was in an accident and old parts were reused in reassembly, you may be suffering from fuel leakdown. Your EHA or your fuel distributor may be unable to keep fuel pressure.
What is the condition of your intake boot (between your airflow meter and your throttle body)? Have you checked all the little hoses for vacuum leaks? Have you checked your distributor?
So it's hard to guess at an answer until all the historical details of the car are revealed.
lomtevas is offline   Reply With Quote
Old 12-29-2007, 11:39 AM   #4 (permalink)
z168's Avatar
Date registered: Oct 2005
im sure you cleaned your throttle, replaced the filters, and have good sparkplugs right?
transmission fluid level checked?
Deutsche Tourenwagen Meisterschaft
z168 is offline   Reply With Quote
Old 12-29-2007, 01:15 PM   #5 (permalink)
cruiseoveride's Avatar
Date registered: Jul 2007
Vehicle: 1993 190E 2.3-8v
Send a message via Yahoo to cruiseoveride
distributor ?
cruiseoveride is offline   Reply With Quote
Old 01-01-2008, 10:03 AM   #6 (permalink)
Date registered: Aug 2007
Sounds like your problem is the kickdown switch, located behind the gas pedal. The car idles fine when you are not flooring which leads me to believe you should or have someone replace your kickdown switch.
1996 Jetta GL
1991 190E 2.6
1986 300SDL
Got problems with your car? I can help
Oracle12345 is offline   Reply With Quote
Old 09-19-2008, 09:03 AM   #7 (permalink)
Bruce201's Avatar
Date registered: Jan 2008
Vehicle: 1986 190E 2.3 w/ 5-speed
i had a similar problem with my 88 300te. turned out to be a combo of the distributor w/cap and spark plug wires, so i would check those first.
Bruce201 is offline   Reply With Quote
Old 09-19-2008, 10:10 AM   #8 (permalink)
drewprof's Avatar
Vehicle: 560SEL, 190E, RX7
Those are the easiest to start with
drewprof is offline   Reply With Quote
Old 09-19-2008, 03:08 PM   #9 (permalink)
Date registered: Jan 2006
Vehicle: 1992 2.3 190E
Yeah, I was wondering about the Kick Down, like does it down shift?
If it does , Other ideas - Three things have to happen.
Fuel needs to be enriched. Controlled by the Air Flow Sensor, the Fuel Pressure Reg and Throttle Switch Position switch. There are tests for all in the manual.
Dan
Logon_Bob is offline   Reply With Quote
1985 190E 2.3 Hesitation+Idle Problems MC06A W201 190E, D-Class 4 06-23-2007 01:23 AM
89 190E 2.6 highway speed engine hesitation Tye W201 190E, D-Class 4 03-03-2007 03:56 AM
93 190E 2.3 HESITATION PROBLEMS DA93BENZ190 W201 190E, D-Class 1 11-03-2004 05:06 PM
Newbie: Irregular idle in park or neutral; hesitation; rich; '91 190e 2.3 irieite W201 190E, D-Class 24 01-14-2003 06:03 PM
190E 2.3 Cold Running Hesitation Guest (MBNZ) W201 190E, D-Class 3 06-24-2002 10:45 PM
