» Site Navigation
» Other Sites
Old 11-03-2007, 06:23 PM   #1 (permalink)
getouttamyway
Vehicle: 1991 190e 2.6, 1984 300sd, 1982 VW Caddy (diesel) 1974 BMW-2002 (pending s14 swap)
CA Smog and a 2.6
I picked up my first w201 recently. I have a w126, but its diesel so the Mercedes gassers are pretty new to me. I have a VW with CIS injection so I feel pretty at home with this car. I need to get the thing smogged and I want to button down all the items that could be problematic before I show up. I replaced the fuel filter today (interesting that its the same exact filter used in my VW.. so is the oil filter!). It stalls out the first time you start it, but the second time it starts fine. Idle is a bit rough, as if it's missing. I checked the voltage coming out of the 02 sensor and it does fluctuate, but it only reads .07 volts.. maybe .2 max at certain rpms. I checked on my VW and it reads between .2 and .8 so I think it needs replacement. I picked up a Bosch Mustang 5.0 sensor and I plan on splicing that in tomorrow.
I'm curious about the fuel cap. I was surpised to see the fuel cap on the 190e is similar to the metal one on my diesel (diesels are smog exempt in CA). I know in CA smog they hook your cap up to a machine and make sure its working correctly (evap?) and can fail you for that. this cap looks pretty low tech.. will it pass smog?
The cap looks like this one:
getouttamyway is offline   Reply With Quote
Old 11-03-2007, 07:34 PM   #2 (permalink)
hamada128
hamada128's Avatar
Date registered: Jan 2007
Vehicle: 93 190E 2.3
My cap just passed NJ test 2 weeks ago.
1972 Fiat 128 1100cc
1993 MB 190E 2.3 255K
2008 Lancer 1300cc - Gulf Edition
MB Driver since 10/22/06
hamada128 is offline   Reply With Quote
Old 11-03-2007, 08:16 PM   #3 (permalink)
getouttamyway
Do they take your cap off and hook it up to a machine and test it?
Old 11-03-2007, 08:44 PM   #4 (permalink)
hamada128
hamada128's Avatar
Yep.
Old 11-03-2007, 11:27 PM   #5 (permalink)
getouttamyway
Good to know. I'll just change my o2 sensor tomorrow and take it to a shop and see how it goes.
Anyone have any ideas on the starting issue? Without fail, the first time you start it it'll turn off immediately, then the 2nd time it's fine. It happens regardless if its cold or hot.
## FAILED SMOG again ## hifeverz R129 SL Class 1 05-24-2006 08:36 AM
Smog problem mbmb260e W124 E,CE,D,TD Class 5 06-01-2005 09:00 PM
CA Smog Check jcwish R170 SLK Class 1 12-31-2004 05:54 PM
SMOG PUMP GREEKCS W126 S,SE,SEC,SEL,SD,SDL Class 1 05-28-2004 07:41 AM
Smog Check! 2000ML320SUV W163 M-Class 5 12-12-2003 09:53 PM
