Old 09-09-2007, 04:43 PM   #1 (permalink)
kiez4's Avatar
Date registered: Aug 2007
Vehicle: 1990 Mercedes Benz 300SE; 1984 Corvette; 1986 Honda Goldwing SEi
Help looking to purchase a diesel.
What are your recommendations in the purchase of a w201diesel? Which years were the most reliable and why? What type of mpg is common? Please list any problem areas common to diesels. How many miles are common for a MB diesel engine? Thank you.
kiez4 is offline   Reply With Quote
Old 09-09-2007, 05:17 PM   #2 (permalink)
rjb190e's Avatar
Date registered: Apr 2006
Vehicle: '86 2.3-16 / '90 2.6 '98 C230 '04 Saab 9-3 Turbo
Send a message via AIM to rjb190e Send a message via Yahoo to rjb190e
If you can find one and afford it the 1987 2.5 Turbo has to be the best. I'd guess that highway mileage in a well maintained car would be in the high 30's for a 2.5 and maybe low 40's for a 2.2. The 2.5 Turbos are rare. I'd go with a 2.5 over a 2.2 just to have a little more power and a newer car. Correct me if I'm wrong but I think the last year for a 201 diesel was 1989 for the US. The newest cars you would be looking at would be 18 years old. I'd look for all the usual suspects when purchasing any car that age. As for diesel specific, the most expensive part of a MB diesel is an injection pump. They seem to last forever but check for leaking and make sure the IP timing is where it should be. If it's not it will smoke white or black and have 0-60 times measured in days. Then make sure the glow plug system is working as it should, the car should start right up even when cold. The next enemy will be air in the fuel system. Since these cars are old , rubber lines can and will break anytime. Inspect and replace what you can or pay someone else to do it for you.
rjb190e is offline   Reply With Quote
Help lookking to purchase a diesel. kiez4 W124 E,CE,D,TD Class 3 09-15-2007 06:24 AM
Help lookking to purchase a diesel. kiez4 W123 E,CE,D,CD,TD,TE Class 8 09-09-2007 08:33 PM
Need Purchase Advice 300 Diesel SpiderBC1 W124 E,CE,D,TD Class 2 09-20-2005 04:30 PM
What to look for in used purchase of 240D or 300D Turbo Diesel? soundwavefl W123 E,CE,D,CD,TD,TE Class 7 02-17-2005 06:09 PM
300 Diesel Wagon Purchase advise Wagon dreamer W126 S,SE,SEC,SEL,SD,SDL Class 2 01-03-2005 06:44 PM
