» Site Navigation
» Other Sites
Old 06-18-2007, 04:54 AM   #11 (permalink)
hamada128's Avatar
Date registered: Jan 2007
Vehicle: 93 190E 2.3
BTW, how you know that your Timing Chain Tensioner is bad??
1972 Fiat 128 1100cc
1993 MB 190E 2.3 255K
2008 Lancer 1300cc - Gulf Edition
MB Driver since 10/22/06
hamada128 is offline   Reply With Quote
Old 06-18-2007, 06:59 AM   #12 (permalink)
Jevile219's Avatar
Date registered: Oct 2004
Vehicle: White 1982 Euro 500 SEC (67,000), Black 1982 Euro 500 SEC, 1985 300D Turbo Diesel (329,000 miles!)
He said it was diagnosed by a german/mercedes mechanic
Jevile219 is offline   Reply With Quote
Old 06-18-2007, 09:48 AM   #13 (permalink)
hamada128's Avatar
i know, but i meant this rattling noise.
Originally Posted by MTI
The '85 is a single row chain. The typical indication that there's too much chain slack (stretched chain or failing tensioner) is that there's a rattle on start up that goes away once oil pressure builds up. What's happening is that the old style tensioner relied on oil pressure to push on the chain rail. The updated version uses a coil spring to maintain tension rather than oil pressure.
Old 06-18-2007, 10:43 AM   #14 (permalink)
w201 Über Moderator
Kynyption's Avatar
Date registered: Jan 2006
Vehicle: 1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
Send a message via ICQ to Kynyption Send a message via AIM to Kynyption Send a message via MSN to Kynyption Send a message via Yahoo to Kynyption Send a message via Skype™ to Kynyption
You...listen?
You Can Find Me In The w201...
...Don't Forget to Add Yourself To The w201 Frappr map!...
...Coming soon Projekt Euro
Kynyption is offline   Reply With Quote
Old 06-18-2007, 10:44 AM   #15 (permalink)
hamada128's Avatar
who me??
Old 06-18-2007, 11:00 AM   #16 (permalink)
w201 Über Moderator
Kynyption's Avatar
You asked how to hear the rattle. I'm telling you. You have to listen
Old 06-18-2007, 03:04 PM   #17 (permalink)
Jevile219's Avatar
that's kind of what I was thinking.
Really, what did you mean hamada???
Old 06-18-2007, 04:56 PM   #18 (permalink)
hamada128's Avatar
i mean what kind of noise you should hear and coming from where exactly?
coz sometimes i have the rattling noise but coming from the water pump area.
Old 06-18-2007, 04:58 PM   #19 (permalink)
w201 Über Moderator
Kynyption's Avatar
Comming from the front of the engine, where the chain is located.
Old 06-18-2007, 05:03 PM   #20 (permalink)
hamada128's Avatar
and the water pump is in the front of the engine too, but you know what is weired, now i just installed a new thermostat with plastic cover and drained the cooling system from any trapped air, and i didnt hear the rattling this time, i replaced everything and started the car from cold start which usually gives my that noise if i start it from cold start.
Timing Chain Tensioner Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 12 09-08-2007 11:50 AM
Timing Chain Tensioner Gregs300CD W123 E,CE,D,CD,TD,TE Class 1 05-14-2007 02:33 PM
timing chain tensioner Jippi W201 190E, D-Class 5 06-23-2006 08:43 AM
TDC timing with new chain/tensioner. Jammerkiller W201 190E, D-Class 8 06-17-2006 11:59 PM
Timing Chain ..Tensioner Adjustment? BNZ W126 S,SE,SEC,SEL,SD,SDL Class 2 01-17-2006 09:12 PM
