» Site Navigation
» Other Sites
Old 03-25-2007, 09:07 PM   #11 (permalink)
Date registered: Mar 2007
Vehicle: 1991 Mercedes 190E 2.3L
Originally Posted by skitzy.sht
yer good
cos this guy have no friggen idea, well, in some parts i was like why would he do that when you could do this
also i believe that this is a later model 190e, its definitly not a 2.6
the easiest and funnest way to do it
is just take your whole interior out thats wat i did,
found lots of goodies thats been bured and hidden over the 20 years
german pens? and a silver coin NOT AUSTRALIAN
MY SETUP ( i drew it all up in illustrator )
what else you could do... is pull out the seat... pull the seatbelt off along the driver/passenger side and lift the carpet and run your wires in the channel thats already created
chevypwr1805 is offline   Reply With Quote
Old 03-25-2007, 09:11 PM   #12 (permalink)
skitzy.sht's Avatar
Date registered: Dec 2006
Vehicle: 1987 Signal Red 190e 2.6L
Send a message via MSN to skitzy.sht
im in australia, so everything is reveresed all my cables run allong passenger side, but i do believe that there is cables being feed throught both sides of the boot, i was thinking about taking fotos today about how my cables are being fed through and i think i might brb 1 hours guys
Quoterjb190e "BMWs are girl cars... keep the 190 for yourself."
skitzy.sht is offline   Reply With Quote
Old 03-25-2007, 09:15 PM   #13 (permalink)
milosz87's Avatar
Date registered: Sep 2006
Vehicle: 91' VW Golf GL
Send a message via AIM to milosz87
hey skitzy, can you somehow post that pic you grew?? it seems i cant view it or dl anyhting to view it..
Oh how did I do it, I got right in, it was like liquid fluid.
milosz87 is offline   Reply With Quote
Old 03-25-2007, 09:44 PM   #14 (permalink)
skitzy.sht's Avatar
cant u click on the image miloz? and it starts a downloader?
Old 03-26-2007, 06:57 PM   #15 (permalink)
Vehicle: 87 190E
If U Remove The Drivers Seat,door Trim,and Pull Up The Carpet U Will Notice That Mb Gave Us Nice Snap Down Wire Holders That Will Fit More Wires Than U Need To Wire The Baddest Stereo. Not To Mention The Giant Rubber Grommet Into Trunk Which Can Be Cut To Size For All These Wires Without Risk Of Pinching Or Rubbing Through Ur Power Wire. Also By Moving The Carpet Wires Are Hidden And Cant Be Pinched By Rear Seat. When I Did It I Also Removed Passenger Seat And Carpet From Car. Very Easy To Steam Clean At This Point. Its Lots Of Work But Its Worthit.
JVK420 is offline   Reply With Quote
Old 03-27-2007, 04:22 PM   #16 (permalink)
Vehicle: 1986 190e 2.3 8v
need 2 replace H2O pump
Hey guys thanks 4 the stereo install refresher. The diagram was excellent'e. How does it sound.
I have 2 replace my H2O pump. How do I stop the crank from spinning when loos-ening the fan center bolt.
rasgallo is offline   Reply With Quote
Old 03-27-2007, 04:39 PM   #17 (permalink)
will post for food
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 1/43 scale rickshaw
Sorry,hate to be a dick but that is all wrong! The power wire being pinched between the rear seat and frame is a recipe for a fire
(if you pull the carpet out,you'll see a hole down low near the floorboard to route it) and also the RCA's should be run on the opposite side of the car but it's not overly critical.
Nutz 4 Benz is offline   Reply With Quote
Old 03-27-2007, 08:26 PM   #18 (permalink)
skitzy.sht's Avatar
yes i re wired my car yesturday after learning about u cant have rca next to power,
but in tha pictur eif u lift up that, black rubber foam, it makes it easier to slide it down on the side of it inbetween the chassis and the rubber ( i believe its your locking air pump) and from the side of that it will easily fit through the hole, i have 2 RCA cables, and 2 stinger audio cables goiing through there
Old 03-27-2007, 08:27 PM   #19 (permalink)
milosz87's Avatar
i still cant view that dam pic =[ i want to!! somebody PLEASE send it to me.
Old 03-27-2007, 08:30 PM   #20 (permalink)
skitzy.sht's Avatar
sorry guys heres the file again
this is my setup
( just scroll down to get the file you have to wait 50 seconds aswell free file hosting wat do u expect)
im going to be purcashing a another monoblock amp to power my sub/s and then the existing amp will power my fronts and my rears
how to route wiring from door panel to inside car? sinned81 W163 M-Class 7 08-28-2006 11:28 AM
Shortest route is not always the best LETO R171 SLK Class 12 03-28-2006 07:08 PM
OT: Route 66 LUGNUT R170 SLK Class 9 04-18-2005 10:34 AM
Route 66 malibuite R171 SLK Class 1 03-18-2005 11:23 AM
2004 E55 in route.... houstone55 W211 E55 AMG, E63 AMG 3 03-15-2004 01:16 AM
