Old 03-22-2007, 04:47 PM   #1 (permalink)
Date registered: Oct 2006
Heater Control Illumination
For ages, I'd been bugged that only one of the three heater control knobs of my 190E was illuminated when the headlamps were on - I also suspected that there were other non-functioning bulbs, meant to light up the sliding ventilation fan speed control, and more.
Sure enough, a question asked on this forum confirmed this, so armed with some ridiculously expensive 12v 1.2w bulbs purchased from Hellfords, I set about 'getting-in-there'
The bulbs WOULD have been cheaper from my MB dealer - part number 072 601 012 230, around £ 0.70 each
To clarify before we start, there are 5 bulbs in total - one behind the centre of each of the three knobs, and two further bulbs - one behind the middle knob, and one behind the left-hand knob.
These last two illuminate the knob surrounds, and the five-stage sliding fan speed control
Note - my car does NOT have A/C ...
Step 1 - Remove Knobs
See Photo 1 = http://i156.photobucket.com/albums/t...heaterpic1.jpg
They simply pull off - I'm using a pair of 'vice-grips', with a piece of rag to prevent damage to the knob.
Mine needed a fair old tug to get them off !
Step 2 - Knob illumination Bulbs
See Photo 2 = http://i156.photobucket.com/albums/t...heaterpic2.jpg
If it's just the bulbs behind the knobs that you need to replace, removing the appropriate knob is all you need to do - you'll see the bulb in the end of the tube that the knob rotated around. Pull the old bulb out, and press the new one in,
making sure that the contacts on the new bulb line up with the socket - a bit fiddly.
To get to the other two bulbs - read on ...
Step 3 - Remove Hex Nuts
See Photo 3 = http://i156.photobucket.com/albums/t...heaterpic3.jpg
Not sure what size these nuts are, but my 27 mm socket, although too big, JUST gripped - so probably 25 or 26 mm.
Take care not to damage the bulbs that were exposed when you took the knobs off ...
Step 4 - Remove Knob Surrounds
See -
Photo 4 = http://i156.photobucket.com/albums/t...heaterpic4.jpg
Photo 5 = http://i156.photobucket.com/albums/t...heaterpic5.jpg
The 'bucket' shaped knob surrounds are a press fit into the fascia, and held in place by the nuts - once the nuts are off you can start wiggling the buckets loose, and then out - avoid the temptation to prise them out with anything pointed - you're bound to damage the soft fascia ...
Once the knobs surrounds are out, you should see the bulbs, one located at the bottom left of the LH knob, and the other to the bottom right of the middle knob.
You'll also see the clear plastic 'light-guide' that reflects the light up to the various controls.
The old bulbs were easy enough to pull out with needle-nosed pliers, but tricky to get the new ones lined up to be pressed in to the contacts - take your time, don't rush it.
With the various bulbs replaced, carefully reverse the steps to re-assemble - I didn't see the need to tighten the nuts more than just snug.
Job done !
howard35 is offline   Reply With Quote
Old 03-22-2007, 04:52 PM   #2 (permalink)
1993MB190E's Avatar
Vehicle: 1993 Mercedes Benz 190E 2.3
Send a message via AIM to 1993MB190E Send a message via MSN to 1993MB190E
Looks decently easy, I'm wondering how tough it would be to do on a 2.3 8v because the controls are different. I wonder if the bulbs would the same or not.
1993MB190E is offline   Reply With Quote
Old 03-22-2007, 07:49 PM   #3 (permalink)
skitzy.sht's Avatar
Date registered: Dec 2006
Vehicle: 1987 Signal Red 190e 2.6L
Send a message via MSN to skitzy.sht
mine dont light up also, my interior is scary dark at night, i just guessed that they didnt invecnt knob lights by 1986
care to send us a night picture of your lit up knobs?
Quoterjb190e "BMWs are girl cars... keep the 190 for yourself."
skitzy.sht is offline   Reply With Quote
Old 03-22-2007, 08:33 PM   #4 (permalink)
milosz87's Avatar
Date registered: Sep 2006
Vehicle: 91' VW Golf GL
Send a message via AIM to milosz87
wouldnt it be easier to just put the link where it has [IMG] [/IMG] so you can see the pictures w.o clicking them?
Oh how did I do it, I got right in, it was like liquid fluid.
milosz87 is offline   Reply With Quote
Old 03-22-2007, 09:04 PM   #5 (permalink)
skitzy.sht's Avatar
hes obviosly not very visual, more attracted to nicely incorporated lines and text links
Old 03-22-2007, 09:05 PM   #6 (permalink)
shingleback's Avatar
Date registered: Apr 2006
Vehicle: '87 190D 2.5 Turbo, '03 3.2TL-S 'A-Spec'
I am not sure why the lamps cost you so much; I just bought 30 of them for CDN$0.37 each. Part # 2721 (12V 1.2W). I replaced the one in the (sliding) heater fan control switch last weekend and it is the correct lamp.
shingleback is offline   Reply With Quote
Old 03-22-2007, 09:52 PM   #7 (permalink)
Jippi's Avatar
Vehicle: 1996 Volvo 855 GLT, 1993 Mercedes-Benz 190e 2.3 8v
Send a message via AIM to Jippi Send a message via MSN to Jippi
its fairly easy to replace. the pushbutton units use the same bulbs as the warning lights. i pulled mad bulbs from random dash clusters
Jippi Jak
1993 MB 190E 2.3---work in progress the end product will be a surprise...
1996 Volvo 855 GLT--Project R clone
I need a benz bad........
Jippi is offline   Reply With Quote
Old 03-26-2007, 02:40 PM   #8 (permalink)
Pic of bulbs lit up, as requested ...
Old 06-19-2008, 02:49 AM   #9 (permalink)
edwarddy's Avatar
Date registered: May 2008
Vehicle: Mercedes Benz 190E 1988 Model Japan Version 2.0
hi can you teach me how to use these 3 knobs? thanks. i have a 190E 1988 (201).
edwarddy is offline   Reply With Quote
Old 06-19-2008, 12:45 PM   #10 (permalink)
Date registered: Sep 2007
Vehicle: 1985 190E 2.3, 2007 Acura TL
There are 0.8W & 1.2W bulbs, MB told me to make sure to use the correct wattage bulbs. Otherwise with time the plastic around it will melt if the higher wattage 1.2W bulb was used in place when it should be 0.8W.
cypress188 is offline   Reply With Quote
Replacing bulbs for instruments and control illumination istracpsboss W201 190E, D-Class 8 12-24-2006 10:55 AM
Climate control Illumination Rappidtrac W163 M-Class 2 11-04-2006 10:49 AM
A Tech question regarding climate control illumination roadsession Audio & Telematics Forum 1 01-20-2003 06:07 PM
strangeness with a/c control illumination j [la] R170 SLK Class 6 02-26-2002 01:36 AM
Heater illumination Owen R170 SLK Class 4 05-15-2001 05:19 AM
