» Site Navigation
» Other Sites
Old 03-21-2007, 01:01 AM   #21 (permalink)
skitzy.sht's Avatar
Date registered: Dec 2006
Vehicle: 1987 Signal Red 190e 2.6L
Send a message via MSN to skitzy.sht
*update*
we found the problem
the fuel cutout relay was worn, because there was no outer sheild over it, which where should be,
and its located behind the battery, so water and other elements just got at it over time,
the mechanic had the car running today, and said he just cleaned it up a bit,
but we are buying a brand new one , because it would kark it any time!
tavioman, have you checked that? ( when you turn the ignition, on to electrical power only*not the startup, you should hear the relay tahts located behind the battery, click in, and then you should hear the fuel pump start up, which is undernearth the car, under that plastic gaurd
but we still have a fuel leak, up around the distributor, which will be a very expensive problem to fix, if we have to buy a new one, any ideas on that?
- its a small fuel leak though
very minor,but could still be an issue
Quoterjb190e "BMWs are girl cars... keep the 190 for yourself."
skitzy.sht is offline   Reply With Quote
Old 03-21-2007, 02:41 AM   #22 (permalink)
tavioman's Avatar
Date registered: Jul 2006
Vehicle: Mercedes 190E 2.0L - 1986(black with grey)
My relay it's in good shape. My problem does not come from there.
If there is a fuel leak around the distro you should check from where it comes. If you're lucky the problem lies in EHA (little black box attached to the fuel distributor). You could find another one at a junkyard. A new one it's pretty expensive. Not to mention the fuel distro....
tavioman is offline   Reply With Quote
Old 03-21-2007, 02:42 AM   #23 (permalink)
tavioman's Avatar
It could be also just the o-rings between the EHA and distro. Thats very cheap.
Old 03-21-2007, 03:18 AM   #24 (permalink)
skitzy.sht's Avatar
i hope so,
because a whole new distro, is at least 2 thousand
to australia
Replacing the diesel shutoff solenoid valve Cyberbach W123 E,CE,D,CD,TD,TE Class 3 02-05-2006 05:43 PM
Looking for mechanic/help replacing shutoff valve DC/VA/MD jbhashem W123 E,CE,D,CD,TD,TE Class 1 11-11-2005 02:38 PM
99 E300 turbodiesel fuel leak, electrohydraulic shutoff box bhowell_10 W210 E-Class 3 10-01-2005 02:46 PM
fuel shutoff solenoid ggenovez Vintage Mercedes-Benz 2 07-16-2005 01:27 AM
560 Fuel Shutoff?? jcantor W126 S,SE,SEC,SEL,SD,SDL Class 0 09-18-2002 04:14 AM
