Old 02-25-2007, 11:13 PM   #1 (permalink)
wvh187's Avatar
Date registered: Aug 2006
Fan Belt
My Fanbelt is making noises... i was told that it could be dirty . cause its not loose or seomthing such as coolant got on it and it makes a noise you cant get rid of... but anyways anyone know how to get rid of the noise.... the noise its coming right from where the belt tensioner is at... if i spray it with windex or somethin of that sort it goes quiet for a couple min then comes right back.... think it just needs to be lubed.... the tensioner
wvh187 is offline   Reply With Quote
Old 02-26-2007, 12:20 AM   #2 (permalink)
w201 Über Moderator
Kynyption's Avatar
Date registered: Jan 2006
Vehicle: 1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
Send a message via ICQ to Kynyption Send a message via AIM to Kynyption Send a message via MSN to Kynyption Send a message via Yahoo to Kynyption Send a message via Skype™ to Kynyption
Lube the tensioner then?
You Can Find Me In The w201...
...Don't Forget to Add Yourself To The w201 Frappr map!...
...Coming soon Projekt Euro
Kynyption is offline   Reply With Quote
Old 08-02-2007, 09:12 AM   #3 (permalink)
Look at the tensioner from the side. The bearings maybe worn letting the tensioner set at a bit of an angle causing the belt to be pulled against the lip of the pulley just before the tensioner pulley.
The tensioner pulley with the bearing in it is aprox. $39 from MB. If they quote something around $74 they are probably trying to sell you the pulley and the bracket. I didn't need the bracket to repair mine.
MicroDC is offline   Reply With Quote
Old 08-02-2007, 09:39 AM   #4 (permalink)
hamada128's Avatar
Date registered: Jan 2007
Vehicle: 93 190E 2.3
what kind of noise is this one? rattling noise?
1972 Fiat 128 1100cc
1993 MB 190E 2.3 255K
2008 Lancer 1300cc - Gulf Edition
MB Driver since 10/22/06
hamada128 is offline   Reply With Quote
Fan Belt Tensioner The Melmaan W201 190E, D-Class 5 12-01-2006 05:36 PM
Fan Belt Braingears G-Class 2 04-10-2006 08:39 AM
Help with Fan Belt Brian Felts W124 E,CE,D,TD Class 1 10-23-2005 08:44 AM
190 fan belt tighten? Peter_190 General Mercedes-Benz 1 06-03-2005 06:00 AM
servo fan belt Tjærand G-Class 2 09-18-2002 06:47 AM
