» Site Navigation
» Other Sites
Old 01-23-2007, 06:40 PM   #1 (permalink)
strd27
Date registered: Jan 2007
Vehicle: 1984 190e 2.3L euro
Exclamation I need help many say in more ways than this
Hi I am so glad to be able to post with you I have been to other fourms not 1 person has got back with me to help or tell me to buzz off it looks like you really want to help each other. Thanks. This is my very 1st ever Mercedes-Benz and it is a 1984 190e I had 2 problems now I only have one the 1st was a clutch problem it only needed to be blead that is done clutch works great now the 2nd on I am working on is the car will start idle for about 30 sec then die but if I remove the top of the air cleaner and ever so slightly move the air flow flap the car will run forever and rev up all the good stuff but if I let it come back to idle with out the air flow flap moved so very little it dies. I have bought manuals both haynes and chilton both don't say to much about the idle system both say the comp controls the idle I thought it may be the cold start system so I let it run with the flapper mover unitl the fan came on and the car was up to temp but it was the same thing. I went on ebay and found a Mercedes-Benz factory maintance manual is this the manual I need to diag the idle system I have looked for a vac leak but its been very cold here could not stay out more than 1 hr at a time am I over looking something? Sorry for the long post I really like the car I just need a little help Thanks
strd27 is offline   Reply With Quote
Old 01-24-2007, 12:28 PM   #2 (permalink)
DAN57
DAN57's Avatar
Date registered: Jan 2006
Vehicle: 190E 3.0
Hello and welcome to the forum.
I think you may be on the right track looking for an air leak. You will find the bottom half of the air flow meter is made from rubber. On the bottom of this rubber section is a pipe about 30mm (half inch) diameter. My guess would be this pipe has dropped off. From memory this pipe comes from the idle air valve so not only would you have an air leak but the idle valve is unable to compensate for it.
You may also find the lower rubber section of the air flow meter split. But this is less common.
Good luck
DAN57 is offline   Reply With Quote
Old 01-24-2007, 05:08 PM   #3 (permalink)
Jippi
Jippi's Avatar
Vehicle: 1996 Volvo 855 GLT, 1993 Mercedes-Benz 190e 2.3 8v
Send a message via AIM to Jippi Send a message via MSN to Jippi
i dun know about the clutch but, the idle issue unless you have the tools its a lot of guess and check. the earlier 190e's had an adjustable iacv, adjust that and see how it does, make sure u mark the orig position. if not adjust the amm (using a hex key) turn the screw in the hole on the center of the air cleaner. whats the position of your distributor? you can retard and advance ur timing there. the screw should be about center. i say that you take apart your intake manifold and reseal the bottom of the air flow meter, the throttle, and the intake itself. this is a good time to clean the intake too.
Jippi Jak
Totaled 6-27-05: 1985 MB 190e 2.3
1987 MB 190e 2.3-- sold
1993 MB 190E 2.3---work in progress
1996 Volvo 855 GLT
I need a benz bad........
Jippi is offline   Reply With Quote
Old 01-24-2007, 06:54 PM   #4 (permalink)
strd27
More questions
Where can I find the engine number the local dealer says I will need it because my 190e is european. Great what does that mean to me. I called them to find the center bezel on my heater control asm he said I have push button controls I told him I don't think so and I told him what I have. I have 3 control knobs the center one controls were the air flow goes (I think) I need the bezel with the arrows on it. He has not called me back yet
Old 01-24-2007, 06:55 PM   #5 (permalink)
Kynyption
w201 Über Moderator
Kynyption's Avatar
Vehicle: 1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
Send a message via ICQ to Kynyption Send a message via AIM to Kynyption Send a message via MSN to Kynyption Send a message via Yahoo to Kynyption Send a message via Skype™ to Kynyption
What is your VIN number?
If it starts WDBDA its North American
If it starts WDB201 its European
The manual states the following:
Engine No. (190E: front left) and it has a picture of the car with an arrow pointing to the left as view from the front
For 190E 2.3 engine number is located front left.
You Can Find Me In The w201...
...Don't Forget to Add Yourself To The w201 Frappr map!...
...Coming soon Projekt Euro
Kynyption is online now   Reply With Quote
Old 01-24-2007, 07:12 PM   #6 (permalink)
strd27
Vin info
my vin is WDB2010241A039031 then below that is has ABE WR C750. The dealer says I need to find the engine number and find the 4th number in. Any ideas what all them numbers letters mean.
Old 01-24-2007, 07:23 PM   #7 (permalink)
Kynyption
w201 Über Moderator
Kynyption's Avatar
Look it up on the russian VIN checking website. I dont have the link off hand as i am at work now but if someone has not posted it before i get home i will post it for you.
And you have a Euro Car (Grey Market Vehicle)
Old 01-24-2007, 08:05 PM   #8 (permalink)
Samoila Stefan
Samoila Stefan's Avatar
Vehicle: Dodge Caravan 3.0 2000 / Mercedes 190E 2.0 1983 / Dacia 1310 TLE 1.4 1990
Send a message via ICQ to Samoila Stefan Send a message via AIM to Samoila Stefan Send a message via MSN to Samoila Stefan Send a message via Yahoo to Samoila Stefan
Wdb2010241a039031
VIN WDB2010241A039031
Model 190 E
Chassis 2010241A039031
Engine 102961 10 048426
Transmission 716216 00 006127
Order 0 3 245 00012
Approx. year 1983
Lights BOSCH
Cab 69524
Dealer Mainz branch (245)
Interior cloth quartz (055)
Paint
877 blue green metallic (с 01.01.1979 по 31.12.1990, с 1994)
410 electric sliding roof (с 01.03.1965 по 29.02.1988)
422 mercedes-benz power steering (с 01.01.1963 по 29.02.1986)
536 interference suppression without radio set and mechanically operated antenna (с 01.01.1970 по 31.07.1997)
570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
591 heat-insulating glass, all-around, heated rear window pane, (single-sheet safety glass), Germany
green heat-insulating glass all round, heated rear window, single pane safety glass - Germany (с 01.01.1972)
Mercedes 190 E 2.0 (1983) 102.961 engine
"In giving advice, seek to help, not please your friend." - Solon (638-559 BC) Greek lawgiver & politician.
Samoila Stefan is offline   Reply With Quote
Old 01-24-2007, 08:49 PM   #9 (permalink)
strd27
Wow
Were and how did you get that. Thats GREAT THANK YOU.
Old 01-24-2007, 08:51 PM   #10 (permalink)
Samoila Stefan
It's no secret: Mercedes-Benz Club Russia | Mercedes-Benz / VIN
Parting Ways Xander W126 S,SE,SEC,SEL,SD,SDL Class 6 10-01-2006 08:36 PM
Any easier ways???? 430convertible W208 CLK Class 4 02-24-2006 05:40 PM
Any easier ways??? 430convertible Audio & Telematics Forum 4 02-24-2006 05:39 PM
'01+ Moonroof goes both ways? bs00clk W208 CLK Class 7 11-04-2005 11:08 AM
Very mysterious ways deathrattle Off-Topic 14 11-01-2005 11:50 AM
