Old 01-10-2007, 03:44 AM   #1 (permalink)
Samoila Stefan's Avatar
Vehicle: Dodge Caravan 3.0 2000 / Mercedes 190E 2.0 1983 / Dacia 1310 TLE 1.4 1990
Send a message via ICQ to Samoila Stefan Send a message via AIM to Samoila Stefan Send a message via MSN to Samoila Stefan Send a message via Yahoo to Samoila Stefan
Fuel level indicator does not drop
Fuel level indicator does not drop right after I turn off the key (this not happened before I filled the tank). The electrical alarm commands the blinkers to activate for 30 seconds if the door is opened. The gauge drops down only with the door open so the "rhythm" of the blinkers get into the gauge and resets it... so in simple words with every blink the indicator goes to the left one bit, when it's at the middle drops down completely (3-4 blinks needed...) Any ideas for this one?
Mercedes 190 E 2.0 (1983) 102.961 engine
"In giving advice, seek to help, not please your friend." - Solon (638-559 BC) Greek lawgiver & politician.
Samoila Stefan is offline   Reply With Quote
Old 01-10-2007, 04:48 AM   #2 (permalink)
lomtevas's Avatar
Date registered: Nov 2006
Vehicle: 1986 190E 2.3-16, 1992 190E 2.3 and 2007 GL450
Send a message via Skype™ to lomtevas
Remove the alarm and replace/repair any damaged wires.
This may also explain your stalling problem. If the alarm stalls the motor as part of its protective function, then that answers the question in your previous post regarding the stalling.
lomtevas is offline   Reply With Quote
Old 01-10-2007, 06:33 AM   #3 (permalink)
I'll try that when I'll put back that sensor by monday. TOmorrow I'll take a pic of the trunk ground area (maybe there's a ground I've moved or covered with paint when soundproofing the trunk...) I have only one ground there that I can see, under the hinge, I'll check that first. Can the engine start w/o that ref sensor? I doubt it, so I'll remove the alarm and see what happends...
Old 01-10-2007, 06:56 AM   #4 (permalink)
manymercsmike's Avatar
Date registered: Aug 2006
Vehicle: CL500, CL500, 190E 2.6, 420 SEC, 350 SL
Wondering if this is also my problem. There is an alarm on my car, which I don't think is factory fitted. There's a small LED in the dashboard, next to the rear window demister switch. The car came with a small alarm fob, which you use to disable the alarm. I would like to remove it - what are the risks?
Current metal:
2002 (C215) CL500 (Batmobile), Obsidian Black, 53k miles
1997 (C140) CL500 (Bismarck), Emerald Black, 131k miles
1991 (W201) 190E 2.6 Sportline (Blake), Almandine Red, 133k miles
1990 (C126) 420 SEC (Bruce), Astral Silver, 109k miles
1978 (R107) 350 SL (Boabby), Signal Red w/ silver hardtop, 115k miles
manymercsmike is offline   Reply With Quote
Old 01-10-2007, 07:23 AM   #5 (permalink)
Your (in fact the car's) fuel needle has the same behaviour (manymercsmike)?
Old 04-05-2007, 08:00 AM   #6 (permalink)
Jippi's Avatar
Vehicle: 1996 Volvo 855 GLT, 1993 Mercedes-Benz 190e 2.3 8v
Send a message via AIM to Jippi Send a message via MSN to Jippi
stefan, did u ever fix ur fuel gauge? im having issues with mines. what happens is that when i fill it gauge is full, after 50 or so miles of driving the needle is at half was. scared me b/c i thought it was consuming alot of gas. then at about a 100 miles its on empty but the light doesnt come on. so i fill it only about 6 gallons of gas are gone at 140 miles. like it should be, but the gauge dances around when i drive on the high way. u think its a gauge issue or a sender issue?
Jippi Jak
1993 MB 190E 2.3---work in progress the end product will be a surprise...
1996 Volvo 855 GLT--Project R clone
I need a benz bad........
Jippi is offline   Reply With Quote
Old 04-05-2007, 08:50 AM   #7 (permalink)
I've checked the ground wire near the sunroof motor.... after I soundproffed the trunk I've messed with it with paint, cleaned it, put a new screw there, now everything is ok...
Old 04-05-2007, 04:33 PM   #8 (permalink)
n0alpha's Avatar
Date registered: Mar 2004
Vehicle: Silver 1994 C280
Hmmm, could be both the sender and the gauge. I had a goofy fuel needle, and replacing the sender helped, but I never quite got it 100% fixed, because the needle had issues too.
Silver 1994 C280
125,000 miles
Mercedes: Time-tested engineering, timeless styling.
n0alpha is offline   Reply With Quote
Old 04-06-2007, 04:30 AM   #9 (permalink)
Jippi's Avatar
gotta find time to play with it
Old 04-06-2007, 04:34 AM   #10 (permalink)
While playing with those avoid magnetisation by using magnetic tools as screwdrivers and such...
Coolent level indicator faulty sss11 W126 S,SE,SEC,SEL,SD,SDL Class 3 08-04-2006 09:57 PM
Rear bench doesn't drop down level to cargo area Bigblue527 W163 M-Class 5 09-01-2005 11:11 PM
Engine coolant level indicator dan_boston R170 SLK Class 3 09-26-2004 05:24 PM
HELP, OIL LEVEL INDICATOR FLASHING with NO REASON ALEX 500SE W140 S-Class 2 05-18-2004 01:18 PM
Stupid question on oil level indicator... C230Komp R170 SLK Class 10 01-21-2004 08:44 AM
