» Sponsor Links
»Garage Storage and Cabinets
Old 01-04-2007, 02:32 PM   #1 (permalink)
hamada128's Avatar
Date registered: Jan 2007
Vehicle: 93 190E 2.3
Unhappy SRS Light Turned OFF after Alarm Installation!!
Hi all,
i have a 1993 190E 2.3 engine W201 chasis, i just installed an alarm system with keyless entry at a local shop, but after the system was installed now i have the SRS light off..
anyone can tell what happened and what shgould i do to have the SRS back on?
Thanks alot and i wish you accept me as a new benz member here
hamada128 is offline   Reply With Quote
Old 01-04-2007, 06:21 PM   #2 (permalink)
lomtevas's Avatar
Date registered: Nov 2006
Vehicle: 1986 190E 2.3-16, 1992 190E 2.3 and 2007 GL450
Send a message via Skype™ to lomtevas
If you mean that your dash panel warning light for the SRS system is now off, it is supposed to be off once the engine starts.
However, if it looks as if there is no SRS status light, then it probably fell behind its array and is dangling there not able to be seen.
lomtevas is offline   Reply With Quote
Old 01-05-2007, 07:46 AM   #3 (permalink)
hamada128's Avatar
thanks for your replay,
the SRS used to be ON after you start the car for few seconds then goes back off(normal way)
but since i installed the alarm system the SRS light does not get on at all
also after this issue happened i started hearing (clicking sound) behind the glove box where the relays are located in theside the hood,
i went to the mechanic and he put on the scanner and he said it is ok and might be only the bulb that get burned while the alarm installation process but i dont think it is the bulb since i started hearin the clicking sound from relays area as i told you,
Old 01-08-2007, 03:27 PM   #4 (permalink)
w201 Über Moderator
Kynyption's Avatar
Date registered: Jan 2006
Vehicle: 1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
Send a message via ICQ to Kynyption Send a message via AIM to Kynyption Send a message via MSN to Kynyption Send a message via Yahoo to Kynyption Send a message via Skype™ to Kynyption
Well lomtevas has a good point. The bulb could be burnt out or it could have fallen out of place and is hanging behind yoru cluster. Have you taken the time to pull your cluster and check the bulbs? It really is not a hard or time consuming job, just be sure to remove the speedo cable.
I have been told by a friend of mine (Tim) that the clicking behind the glovebox is caused by the vacuum valve tree, the thing that works off the air sampling pump and adjusts the cabin air temp. The clicking is normal and you have probably only just started to hear it. You hear it when the set point and actual temp are close and it is the valve that controls the heat opening and closing
Now i don't have a NAM car so i don't have this lovely little irritant. But my friend says that when his begins clicking he EITHER makes it warmer or colder (just a bit)
You Can Find Me In The w201...
...Don't Forget to Add Yourself To The w201 Frappr map!...
...Coming soon Projekt Euro
Kynyption is online now   Reply With Quote
Old 01-08-2007, 03:31 PM   #5 (permalink)
hamada128's Avatar
i dont think that it could be the bulb burnt or hanging behind the cluster cause the guy who installed the alarm didnt play around the cluster
also it was working perfect just before he used his electric meter around the Air bag computer underneath the passenger floor mat cause he wanted to make sure that my car does not have the factory alarm
Old 01-08-2007, 03:40 PM   #6 (permalink)
w201 Über Moderator
Kynyption's Avatar
Honestly it could have been just a weird coincidence. That the bulb may have burnt out around the same time your alarm was installed. Like i said its pretty simple to pull the cluster and check for yourself.
Old 01-08-2007, 05:00 PM   #7 (permalink)
hamada128's Avatar
ok i think i will give it a try to check the cluster?
does anyone know any link with pics for how to remove the cluster?
also is there any tricks i should be aware of while i'm doing this SURGERY?
i dont wanna mess up my car now!!!
thanks alot all
Old 01-08-2007, 05:05 PM   #8 (permalink)
w201 Über Moderator
Kynyption's Avatar
thanks alot all
Use the search feature with my name and the terms either "speedo" or "cluster"
I have helped at least 5 - 10 people pull them out so there will be some hits.
Kinds like this one
Originally Posted by Kynyption
Take off your under panel under the steering wheel. If you have a foam knee bolster..Remove that too. get on your back by the pedals and look up. you will see the speedo cable in a clearish blue tube going directly to the back of the speedo, Reach up and untwist it. Get back in your drivers seat. Grab the sides of the cluster wall and pull that shit toward you. (Or if you prefer take off your drivers side vent housing and reach your arm in there and push the cluster out that way, i prefer not to cuz thats too much shit to put back when i'm done) So you can get the cluster out of the hole kinda play tetris with the fucker and see which way is the best to come out. twist turn and maneuver that sucker till you can see all the wires, unplug the all the electrical wires and get it out.
Here is a fun thread
Can the factory alarm be codes so that it beeps when the alarm is engaged and the light flash HACK THT W163 M-Class 0 03-18-2006 08:10 PM
Nokia 6310i installation on 2001 W203 turned into mess. Please help! Plato Audio & Telematics Forum 11 03-15-2004 10:57 AM
Check Engine Light turned itself off bluefrosch R170 SLK Class 0 01-16-2004 01:04 PM
Aux light switch turned on my brake light???? 4benzes W163 M-Class 5 11-18-2002 04:01 AM
BAS/ESP light turned on briefly rogerl W163 M-Class 8 10-02-2002 07:40 PM
