Was changing my gauge faces over to the nice white ones and i think i did everything to the book but now after putting my instrument cluster back my rev meter doesnt move at all.
i calibrated everything back to original but i cannot get the tacho to move at all. i figure its electrical and am afraid i may have somehow messed up the solenoid behind the needles. Any help?
Did you accidently jack your connections when you were taking them out and putting them back? There is clearance between the needle and the guage face? no rubbing? no rubbing on the hole that would stop it and holt it in place?
well the connections in the back are idiot proofed so i dont think i jacked them. There is clearance and if i turn the amature thing in the back of the gauge the needle turns through the whole range.
I assume the tacho voltage goes in through the connector with the arrow.. i'm thinking of trying to use a multimeter on them when i get back home.
I see ur external temp display is bleeding - since you have the cosole out - would suggest - replace it.
I would suggest you call up your local MB Dealer and find out just
how ludicrously overpriced that little LCD is - second only to the VDO LapTimer from
the 16v cars!
Big bucks - there's a reason most of them remain broken & bleeding...
__________________ '93 W201 Euro 1.8 • 568 Signalrot • 16x8J Evolutions W201 ROTM February 2007
ebay the lcd, it cost me 20+shipping, as for the tach check the 12 v wire i circled. that mite be your problem, i made the mistake of not connecting it and thoght it was my tach.
Jippi Jak
1993 MB 190E 2.3---work in progress the end product will be a surprise...
1996 Volvo 855 GLT--Project R clone
I need a benz bad........
Was changing my gauge faces over to the nice white ones and i think i did everything to the book but now after putting my instrument cluster back my rev meter doesnt move at all. i calibrated everything back to original but i cannot get the tacho to move at all. i figure its electrical and am afraid i may have somehow messed up the solenoid behind the needles. Any help?
yes, definitely check the 12V wire. BtW nice assembly. Tool kit looks cool as well!
“One who conquers himself is greater than another who conquers a thousand times a thousand on the battlefield.”
