Old 12-10-2006, 02:59 PM   #1 (permalink)
Date registered: Nov 2006
190 2.6 stopped, wont start help!!!
stopped when moving, with what i thought was fuel fault, replaced fuel filter, replaced fuel relay, checked fuel delivery seems to be
there with ingnition on or off.????spark seems ok haved chcked rotor arm,fuse in overload relay seems ok? now dont know where to go next, used to try and fire but now just spins...........need inspiration
telereaswell is offline   Reply With Quote
Old 12-10-2006, 03:12 PM   #2 (permalink)
lomtevas's Avatar
Vehicle: 1986 190E 2.3-16, 1992 190E 2.3 and 2007 GL450
Send a message via Skype™ to lomtevas
Do you mean to say that when you flick the key to "start", all the motor does is just spins and spin with no start?
lomtevas is online now   Reply With Quote
Old 12-10-2006, 03:29 PM   #3 (permalink)
Jippi's Avatar
Vehicle: 1996 Volvo 855 GLT, 1993 Mercedes-Benz 190e 2.3 8v
Send a message via AIM to Jippi Send a message via MSN to Jippi
does the engine sound different when u try to start it? sounds like u mite have a broken timing chain. i had a few belts break on me but never a chain. if thats the case its time for a new head or engine. pop off the oil cap and see if the chain is still on the cam gear.
Jippi Jak
1993 MB 190E 2.3---work in progress the end product will be a surprise...
1996 Volvo 855 GLT--Project R clone
I need a benz bad........
Jippi is offline   Reply With Quote
Old 12-10-2006, 03:46 PM   #4 (permalink)
lomtevas's Avatar
A broken timing chain on a 2.6 is highly unlikely.
If the chain was broken, then the aluminum pistons would slam into whichever open valves there are being held in place by the stationary camshaft.
He did not mention any striking noises from the motor.
Old 12-10-2006, 03:57 PM   #5 (permalink)
Jippi's Avatar
if the chain is broken the motor "sounds" cuz only the crank spins. when it happens alot of people dont notice the difference in sounds.
Old 12-11-2006, 12:57 PM   #6 (permalink)
engine turns just fine sounds same as always sometimes trys to fire or coughs not broken chain. been there tried that. spark at plugs etc, now smells of fuel which did not at first ie when first broke down.
Old 12-11-2006, 01:35 PM   #7 (permalink)
Yal
Date registered: Sep 2004
I am going to say that if all ignition parts check out ok, that means pulling the distributor and rotor and checking if that is still intact, checking the spark plug wires and checking for spark, then I would check and replace the crankshaft position sensor.
Yal is offline   Reply With Quote
Old 12-11-2006, 01:37 PM   #8 (permalink)
lomtevas's Avatar
A cranking motor smelling of gas OUT OF THE EXHAUST PIPE means that your engine's not getting spark. Open up the distributor cap and see what's happening there. The cap is ceramic, and should clean easily with an abrasive cloth. Also clean the distributor rotor. After that, check your coil at a shop and then the ignition module which is mounted on the top of the driver's side wheel well inside the engine compartment.
A cranking motor with fuel coming OUT OF THE ENGINE COMPARTMENT means a fuel leak. Check and replace any damaged fuel lines.
Old 12-11-2006, 01:51 PM   #9 (permalink)
Jippi's Avatar
un plug the coil wire, and crank the engine. then remove and inspect the plugs and see if you smell gas. or if they are wet, if not you have a possible fuel distributor/ injector issue. if u havent already done that. fuel could be comiing to the engine jus not geting to the injectors
Old 12-11-2006, 04:11 PM   #10 (permalink)
bgoin's Avatar
Vehicle: Classic 92 190E 2.6
I bet it is the "Distributor Rotor Bracket", cost is $31.25. it is the bracket that the "Distributor Rotor" is attached to. Had one break on me, may not see if it is broken until you remove it, the cylindar part breaks with a hair line break, therefore the rotor does not turn. When I brought a new one, the parts person just looked under the counter to get a new one. It gets no lubrication, other than what you put on when new (Borsch makes lubrication).
<font face="arial" color = blue size="2">
Classic black 1992 190E 2.6, with over 250,000 km, Silver 1998 SLK230 (sold)</font>
<font face="arial" color = red size="3">
<a href="http://www.theanswertothemeaningoflife.com" target="_blank">www.theanswertothemeaningoflife.co m</a>
</font>
bgoin is offline   Reply With Quote
s420 just stopped running. won't start but cranks over. s420australia W140 S-Class 8 02-16-2007 04:24 AM
wont start Jippi W201 190E, D-Class 0 10-14-2006 10:15 AM
Start, ran, wont start again horsessmellfunny W123 E,CE,D,CD,TD,TE Class 9 09-06-2006 08:58 PM
Alarm disconnected trans stopped shifting???? 85' 190 e mas942 W201 190E, D-Class 0 01-23-2006 10:09 PM
Window stopped working - where to start? Kbike W123 E,CE,D,CD,TD,TE Class 3 03-08-2004 11:31 AM
