» Site Navigation » Other Sites
11-17-2006, 08:13 PM
#1 (permalink )
Date registered: Nov 2006
Vehicle: 1991 Mercedes 190E 2.3
idler arm?
Has anyone had to replace their idler arm? I just got new tires and had an alignment but the car doesnt seem tight. For example, cruising in the left lane on the highway i have to tilt the wheel to the right because of slope of the road...is this normal? It feels like the left turning is easier and more responsive than turning right. Anyone had this problem?
11-17-2006, 10:16 PM
#2 (permalink )
w201 Über Moderator
Date registered: Jan 2006
Vehicle: 1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
idler arm, new one by me.
Tilting road, generally yes you need to steer to compensate it.
How are your tie rods? one could have loose bearings.
You Can Find Me In The w201 ... ...Don't Forget to Add Yourself To The w201
Frappr map!...
11-18-2006, 10:50 AM
#3 (permalink )
Vehicle: 190E 2.0 Auto
My idler arm bush is not great , I have the new one to fit but to be honest i have not yet figured out what I doing with it!!
11-18-2006, 11:06 PM
#4 (permalink )
Date registered: Mar 2004
The last idler I bought came as a kit , complete with both bushings new bolt washer and nut.
Just drive out the old bushings with a socket or pipe and pull the new bushes in with the bolt with care.
Probably should have done this work before the aglinement job, eh.
11-18-2006, 11:15 PM
#5 (permalink )
w201 Über Moderator
well if you get it done after the allignment job all you need to do is to besure both rods are of equal length to the ones you pulled and you are set.
11-19-2006, 09:48 AM
#6 (permalink )
Date registered: Oct 2005
Vehicle: 1988 190E 2.3
i gotta do my idler arm bushing, tie rods and flex disk. can barely find the time when i got other people's car to work on.
1988 Mercedes Benz 190E 2.3
Thread Tools Display Modes Linear Mode
Similar Threads Topic Author Forum Replies Last Post Idler Arm Disassembly. Need Help!! Sergio W124 E,CE,D,TD Class 0 10-20-2006 06:35 PM idler arm gcmazza W140 S-Class 1 04-07-2006 08:32 PM I need an idler arm on my w116 :( Graberweg W116 S, SE, SEL, SD Class 4 11-22-2005 08:22 PM idler arm? rookierokus W123 E,CE,D,CD,TD,TE Class 1 04-18-2005 10:34 PM idler arm duck W126 S,SE,SEC,SEL,SD,SDL Class 2 02-07-2005 05:04 AM
