Old 11-01-2006, 12:00 PM   #1 (permalink)
shingleback's Avatar
Date registered: Apr 2006
Vehicle: '87 190D 2.5 Turbo, '03 3.2TL-S 'A-Spec'
Vacuum pump connectors
I think I have to rewire the central locking system, as it is blowing the fuse with the pump connectors disconnected. This means that there is a short to ground somewhere in the circuit. However, I am not sure how the system power works and the manual is not too helpful.
Does anyone know the vacuum pump pin IDs? There is a square connector with 2 heavier gauge wires going to it....red and brown. Are these the power/ground to run the pump?
The round connector has 3 pins, 2 of them green and one brown (if I remember correctly). What are these?
Any help appreciated.
cheers
shingleback is offline   Reply With Quote
Old 11-02-2006, 12:08 AM   #2 (permalink)
Samoila Stefan's Avatar
Vehicle: Dodge Caravan 3.0 2000 / Mercedes 190E 2.0 1983 / Dacia 1310 TLE 1.4 1990
Send a message via ICQ to Samoila Stefan Send a message via AIM to Samoila Stefan Send a message via MSN to Samoila Stefan Send a message via Yahoo to Samoila Stefan
Here's a good diagram for the vacuum for the central locks: http://www.detali.ru/cat/oem_mb2.asp...SGR=045&SGN=02
Mercedes 190 E 2.0 (1983) 102.961 engine
"In giving advice, seek to help, not please your friend." - Solon (638-559 BC) Greek lawgiver & politician.
Samoila Stefan is offline   Reply With Quote
Old 11-02-2006, 10:33 AM   #3 (permalink)
Thank you, that is a good diagram. I am looking for the electrical one for that system, would you have that?
Old 11-02-2006, 09:34 PM   #4 (permalink)
I found this: http://www.detali.ru/cat/oem_mb2.asp...SGR=570&SGN=17
Old 11-03-2006, 11:01 AM   #5 (permalink)
Thank you, that shows me the electrical harness routing.
Old 11-03-2006, 11:32 AM   #6 (permalink)
Thank you too, please help me in my threads, please, if you can.
Old 11-06-2006, 11:25 AM   #7 (permalink)
Date registered: Nov 2006
Vehicle: '86 190E 2.3 5spd
I'm having trouble with my central locking system as well. Trying to find wiring info is not easy. My Haynes manual doesn't show anything regarding the vacuum pump wiring. I can't detect any power on any of the wires on the pump connectors and the fuse in the main box is good. I'd like to bench test the pump but not sure where to connect the power. I assume power goes to the red/brown wires. Question is how to activate the pump with the other connector (green/yellow wires).
Just a thought for you: the fuse is shared for the vacuum pump. Are you sure that its the wiring to the pump that is causing the short/overload? I can't remember right now which are the other devices on that fuse. I think they might be the rear interior lights...
Yorgi is offline   Reply With Quote
Old 11-06-2006, 08:11 PM   #8 (permalink)
Yes, the rear dome lights. If you take a close look at the wiring diagram, you will see that the power is split in the central locking system as well; goes to the pump via the red wire on the rectangular connector. It also goes to the 2 front door vacuum elements as well as the trunk vacuum elements. These elements send control signals to the pump via the wires in the round connector. I believe the 2 green ones are the control wires, but I have not had the time to examine the diagram closely enough.
First I have to disconnect the 3 vacuum actuators to determine where the short is. However, I need to either rewire or replace the harness, as part of my harness is nicely melted into a hard ball inside the wiring conduit. The previous owner must have done a bit of rewiring (he is an electrician) as there is some house wire in that conduit....guess where it is going? To the RH door element!
I think it will save me a lot of headache if I just rewire the system.
Good luck.
Vacuum Pump? demoore17 W124 E,CE,D,TD Class 2 03-08-2006 05:59 AM
Accessing the vacuum connectors under the dash/interior AMSOIL300CDT W123 E,CE,D,CD,TD,TE Class 2 07-08-2005 09:55 PM
Vacuum Pump $$$ Dingo Dave W140 S-Class 12 10-17-2004 11:48 AM
VACUUM PUMP DORIAN R129 SL Class 1 08-21-2004 07:59 AM
Vacuum Pump Guest (MBNZ) W140 S-Class 3 07-24-2001 05:08 PM
