» Site Navigation
» Other Sites
Old 10-24-2006, 09:31 PM   #1 (permalink)
Date registered: Apr 2006
Erratic Idle
So, I am pulling into the drive way with my wife, I put the car in P and all of a sudden the car starts to idleing (sp) really erratic. Usually it will idle at 500 RPM.............today it started reving at 1000RPM and then it would rev up and down from 500 up to 15000 RPM's........................what the hell is going on??
Help please.......................thank you. Oh, I have a '93 190 2.6 with 130K...............just did tune up, etc.................
andyv94 is offline   Reply With Quote
Old 10-24-2006, 10:03 PM   #2 (permalink)
Jammerkiller's Avatar
Date registered: Jul 2005
Vehicle: 1991 300SE, 1987 2.3-16
Check your Over Voltage Protection (OVP) relay's fuses. Worth a shot.
"Imagination is more important than knowledge"
Jammerkiller is offline   Reply With Quote
Old 10-25-2006, 04:46 AM   #3 (permalink)
milosz87's Avatar
Date registered: Sep 2006
Vehicle: 91' VW Golf GL
Send a message via AIM to milosz87
it acaully could be as simple as your floor mat getting under your gas pedal, that was the case for me lol
Oh how did I do it, I got right in, it was like liquid fluid.
milosz87 is offline   Reply With Quote
Old 10-25-2006, 05:21 AM   #4 (permalink)
Date registered: Aug 2005
Vehicle: 1993 W201 190E 1.8i
i think he was the best of all the Monty Python crew.
oh, sorry.
you said Erratic Idle.
190Evoluzione is offline   Reply With Quote
Old 10-25-2006, 05:10 PM   #5 (permalink)
It could be a number of things, it could simply be something clogging an injector. Let it cool down overnight, if it starts the same way, drive on the highway for a couple of mile, that should clear it up. If that doesn't work, it's most likely the idle/speed control valve. You can remove it and try to clean it with carburetor cleaner.
1992 190E 2.3
1989 300SE
1992 300E
1989 Sterling 827 SLI
1982 BMW 733i
1996 Chevy Suburban 4WD
1970 VW Bug
fbotros is offline   Reply With Quote
Old 10-26-2006, 01:19 PM   #6 (permalink)
DAN57's Avatar
Date registered: Jan 2006
Vehicle: 190E 3.0
There is also a air flow potentiometer on the front of the air flow meter just behind the fuel pressure regulator, these can often cause irratic idle. I'm not sure of the test procedure off the top of my head but 5v at idle rings a bell. (Maybe somebody could clarify?) I just fitted one on mine this evening to cure the same problem. Probably worth checking the other bits listed above first as these are easier to do.
DAN57 is offline   Reply With Quote
Erratic engine idle and at lower RPMS Ramesh Bala W124 E,CE,D,TD Class 0 09-06-2005 12:08 PM
Diagnosis for intermittent erratic idle C230Kto380SL R/C107 SL/SLC Class 4 08-06-2005 03:46 AM
123-230E Erratic idle W123-230 Iratic idle 123-230E W123 E,CE,D,CD,TD,TE Class 0 04-08-2005 12:14 PM
Erratic Idle Quick Fix hoggy W126 S,SE,SEC,SEL,SD,SDL Class 0 11-26-2004 03:22 PM
Erratic idle and launch Hellme W201 190E, D-Class 11 07-07-2004 01:08 PM
