Hey everyone. Hearing a bit of noise from my front brakes and I know they are low so its time to replace them. I want to upgrade them (on a budget as usual!)
What other canny ways are there to improve my braking setup? I am interested in more powerful calipers if any one knows were I could pick a set up cheap ish.
Also I replaced my front shock mounts this evening, was a very straight forward job. Worth doing as the old ones were split across the middle!
Andy
*Its amazing how a 20 year old mercedes is more reliable than a 10 year old landrover*
Remember, if you install something like E320 calipers (4 piston) you had better have 17"s or bigger. My stock 15" wheels will no longer fit on the 16v with the E320 calipers installed.
"Imagination is more important than knowledge"
if you have the solid front disc brakes, then yes the brakes from 190E 2.6 are a slight upgrade (but you will need the calipers as well). The brakes from the 300E are slightly larger than those of the 190E 2.6 (but you will need calipers as well). E320/400E/E420 brakes are larger than 300E brakes (but you will need calipers as well).
You can fit E320/400E/E420 brakes with 15" alloys, as they came stock this way. also the "lightweight" 16" clk wheels offset fit E320/400E/E420 brakes as well.
