Old 10-23-2006, 07:51 PM   #1 (permalink)
Date registered: Oct 2006
87 mers 190E 2.3L HELP CAR DIES OUT starts on Cold
Hey all
got a 87 Mers 2.3 190e anyways Cars Starts when its cold and can be driven for a while after that it DIES and wont start, have to wait Few min and it will only start when giveing it GAS and holding it as soon as you let go of the gas pedal it dies
what can be the problem how do i fix this ?
Coil bad needs to be replaced ???
NightOfDarkness is offline   Reply With Quote
Old 10-24-2006, 07:58 AM   #2 (permalink)
Yal
Date registered: Sep 2004
How long before it dies. Does it die when it gets to operating temp, around 80 on the temp guage? If this is the case check you OVP relay. Check the fuse on top of the relay to start with
Yal is offline   Reply With Quote
Old 10-24-2006, 03:14 PM   #3 (permalink)
ok i just when out side and checked and it dont even start any more, its trying but wont start
Old 10-25-2006, 02:01 PM   #4 (permalink)
Yal
How does it not start. Explain the noise it makes when you try to start.
Starts, then dies 190E_goon W201 190E, D-Class 0 12-13-2005 11:24 AM
My 190E starts fine, but then it dies... New_User W201 190E, D-Class 10 02-05-2005 11:13 PM
Help! car dies abruptly, then starts right up and runs fine? kmbonomo R/C107 SL/SLC Class 2 09-01-2004 02:05 AM
Car starts then barely idles, press gas & dies?? digsand W126 S,SE,SEC,SEL,SD,SDL Class 3 03-11-2004 10:28 AM
280E Starts and Dies, starts and dies.... GermanCarNut W123 E,CE,D,CD,TD,TE Class 3 02-07-2004 07:28 PM
