Old 10-29-2006, 10:29 AM   #11 (permalink)
LeftCoastBias's Avatar
Date registered: Feb 2006
Vehicle: 2 bmw's, 2 mercedes & 1 volvo
Send a message via AIM to LeftCoastBias
Originally Posted by Pawsh
online repair manual?
you got a link to one?
-JP
LeftCoastBias is offline   Reply With Quote
Old 11-19-2006, 12:24 PM   #12 (permalink)
the part i recieved from bekkers only has 1 pin.
i can't locate anything like it in the engine bay.
here's the part i recieved:
Old 11-19-2006, 12:29 PM   #13 (permalink)
slk230red's Avatar
Date registered: Mar 2004
Vehicle: '01 SLK230,'93 190E 2.3
It should have 3 pins and it is color coded.
If it ain't broke, BREAK IT.....and make it better.
2001 SLK230
1993 190E 2.3
1971 Corvette LS5 Roadster
slk230red is offline   Reply With Quote
Old 11-19-2006, 12:41 PM   #14 (permalink)
so do i have the wrong part?
oh, and here's a picture of the engine bay.
can anyone point out where that part is supposed to go?
Old 11-19-2006, 12:48 PM   #15 (permalink)
here's a pic of what the service manual (online) says it should look like:
http://mb.braingears.com/201_DISK1/PDF/30012.pdf (page 57)
...but looking here, there looks to be multiple shapes for the same part?
http://www.performanceproducts4benz....e+Gauge+Sensor
Old 11-19-2006, 01:05 PM   #16 (permalink)
here's a couple pics of my best guess as to where it goes...
but the rear most plug thing has 4 prongs, not just 1.
anyone know if i just recieved the wrong part, or am i looking in the wrong area on my engine?
Old 11-19-2006, 02:34 PM   #17 (permalink)
slk230red's Avatar
Just to understand...are you trying to replace the sensor that operates your temperature gauge? Or. a sensor for your aux. fan or main fan?
Old 11-19-2006, 03:06 PM   #18 (permalink)
i got a check engine light; diagnosed it as code 3: coolant temperature sensor.
that is all that i know, the rest i'm winging. i ordered the part from bekkers, after telling them what error i had.
Old 11-19-2006, 05:15 PM   #19 (permalink)
slk230red's Avatar
OK, I see you have the California model that came with the check engine light. It's just a matter of locating the sensor location. Someone on this forum should know.
Old 11-19-2006, 05:53 PM   #20 (permalink)
easier said than done.
i've got 6 forums looking for this stupid part.
coolant temperature sandcuser W140 S-Class 1 06-14-2004 08:22 AM
Coolant Temperature is Climbing Alex///AMG W163 M-Class 6 05-04-2004 09:42 AM
Coolant temperature gauge Twitch W126 S,SE,SEC,SEL,SD,SDL Class 0 04-16-2004 08:16 AM
Coolant temperature sensor Andrey W124 E,CE,D,TD Class 5 01-29-2003 11:53 AM
Coolant temperature for 300e Guest (MBNZ) W124 E,CE,D,TD Class 5 03-05-2001 03:28 AM
