» Site Navigation
» Other Sites
Old 09-26-2006, 11:32 AM   #1 (permalink)
Jippi's Avatar
Vehicle: 1996 Volvo 855 GLT, 1993 Mercedes-Benz 190e 2.3 8v
Send a message via AIM to Jippi Send a message via MSN to Jippi
EM Klutch Fan
ok this is real weird. i had problems with the fan not turning on when the car hits the rite temp. i warmed the car up to about 100 degrees or so and measured the voltage at the klutch connector near the t-stat. theres about 12-13 volts going in to the em klutch but the fan is not turning on. so naturally i thought the em klutch was broken, but when i connect the em klutch directly to the battery it works. so where is it going wrong? theres 12 volts going into the klutch at the rite temp but the klutch isnt kickin on where am i going wrong? i put a working klutch in and same thing. whats the next step i should take?
Jippi Jak
Totaled 6-27-05: 1985 MB 190e 2.3
1987 MB 190e 2.3-- sold
1993 MB 190E 2.3---work in progress
1996 Volvo 855 GLT
I need a benz bad........
Jippi is online now   Reply With Quote
Old 09-26-2006, 03:50 PM   #2 (permalink)
Jammerkiller's Avatar
Date registered: Jul 2005
Vehicle: 1991 300SE, 1987 2.3-16
If there is voltage at the connector, but it only works when you straight wire it to the battery, then it may not be getting enough amperage. You could have a reading of 12-13 volts, but it may be weak. Also, shouldn't the voltage be around 13.6? Maybe the voltage regulator in the alternator is going bad and can't supply enough current to the clutch. How is your battery charging status?
"Imagination is more important than knowledge"
Jammerkiller is offline   Reply With Quote
Old 09-26-2006, 05:33 PM   #3 (permalink)
Date registered: Sep 2006
Your fan clutch switch is bad, it's a 3 pin switch located on the head. part #0065456124 or #0065459124 (double check which one). The Aux fan should come on at 120 degrees but you shouldn't drive the car.
1992 190E 2.3
1989 300SE
1992 300E
1989 Sterling 827 SLI
1982 BMW 733i
1996 Chevy Suburban 4WD
1970 VW Bug
fbotros is offline   Reply With Quote
Old 09-27-2006, 08:44 AM   #4 (permalink)
Vehicle: 1991 190e 2.3, 1981 300D Euro, 1998 BMW 328i
When the ignition switch is on, there is always voltage present at the Positive side of the clutch coil because the EM fan clutch works by grounding the Negative side through the temp switch. Short the correct 2 wires at switch and if the clutch coil is OK , the clutch will engage. Then the swich is probably defective. The switch should close at 100 degrees C.
jmas2k is offline   Reply With Quote
Old 09-27-2006, 02:43 PM   #5 (permalink)
Jippi's Avatar
wait jmas. when the switch closes it should get 12 v power and not a ground, im pretty sure of that. if i recall correctly, the switch i have is a 100/110 switch. the aux fan comes on at 110. like i said when the car reaches 100 deg it switches so that there is a 12 volt signal at the klutchs pos wire. but when i get time i will check the cars charging system. rite now i started classes and dun have the time i use to have.
Old 09-30-2006, 03:47 PM   #6 (permalink)
Jippi's Avatar
ok well i measured it and at the sensor the common wired of the switch is geetinf 11.8 volts and the klutch is getting 12.6 volts or so. the battery is getting 13.8-14 volts. where does the sensor common side get its power from? and what could be causing the sensor's common side not to get enough power. the alt is a bosche reman piece.
thanks
Old 10-18-2006, 11:35 AM   #7 (permalink)
Jippi's Avatar
well i got brand new sensors and relays and it soes the same thing, theres not enough voltage getting to the em klutch to allow it to kick in by itself. i also put in a new battery and a check over the electrical work i did when i fixed it and is fine. anyone have any idea of what can be causing the low voltage to the em klutch.??
Old 10-18-2006, 01:52 PM   #8 (permalink)
Yal
Date registered: Sep 2004
I think you should let it continue to get hot. It should kick in a couple of mm above the 100 mark.
Yal is offline   Reply With Quote
Old 10-18-2006, 04:00 PM   #9 (permalink)
Jippi's Avatar
the sensor switches and theres 12volts going into the clutch but the clutch doesnt come on. few minutes later the aux fan iin front on the rad kicks in. but the voltage going to the em klutch is a little less then 13 volts.
Old 10-19-2006, 07:11 AM   #10 (permalink)
Yal
Ok so how do you feed battery power to the clutch to get it to work? Do you take the wire from the sensor and feed it 12v from the battery? Is it possible that the wire from the sensor to the clutch is bad? Run a new wire from the sensor directly to the clutch and see if that kicks in the fan when the sensor switches.
Bolts for fan/fan clutch tmoc W163 M-Class 2 07-13-2006 12:28 PM
Installation Help - Fan and Fan Clutch tmoc W163 M-Class 0 06-28-2006 06:28 PM
aux fan/cooling fan m4411b W201 190E, D-Class 12 03-06-2006 08:00 AM
126 HVAC Fan not working / Heater Fan Removal cam69ss W126 S,SE,SEC,SEL,SD,SDL Class 1 01-25-2005 10:31 AM
Electric Fan v's clutch fan Christian G-Class 0 03-16-2002 05:13 PM
