Old 09-12-2006, 07:36 AM   #1 (permalink)
Date registered: Sep 2006
Automatic Transmission Issues
Hello everyone, I'm new here, very interesting forum. Lots of Info and Pics. Here's my first question, that I'm sure it has been answered somewhere but didn't find it.
My father-in-law bought a few days ago a 1985 190E 2.3 Automatic, it needs a lot of repairs, you can consider this a project car. The engine is running fine, some things are needed, but the most important thing needed is to make the transmision to shift. The problem is that when you put it in D an start driving the car seems to be in the highest gear, you have to go down to 3 or 2 and the car shifts fine, very smooth. The problem is that we don't how if that is a problem with the transmision or something else, I read through some post and there seems to be a vacuum modulator in the transimsion, and a cable that needs to be adjusted in order to the car to shift properly, but the forums talked about cars that wouldn't shit up, from 1st to 2nd, etc. Does the same applies to our problem? This cable needs adjusment in order to the transmision to shift in the correct order?
The fluid is ok, some minor leak, but ok.
Sorry for my english, haven't practiced in a few years.
wawoola is offline   Reply With Quote
Old 09-12-2006, 08:22 AM   #2 (permalink)
UncleBenz's Avatar
Vehicle: E320 1997, Smart 2008
Send a message via MSN to UncleBenz
I had the same problem. The pressure cable will help the auto trans to shift at a higher RPM or lower RPM. It might help but the problem is the auto trans "fatigue".
My mechanic added a "stop leak" fluid (all the bottle) into the trans (less than $7.00!!!) . It took 2 to 3 days and the trans started to work normally and accordingly to my mechanic, my problem is solved!
Uncle Benz
UncleBenz is offline   Reply With Quote
automatic transmission 428 lily G-Class 2 08-22-2005 07:43 PM
automatic transmission C-SportcoupeC270 W203 C-Class 3 08-05-2004 09:27 PM
Automatic transmission osoro General Mercedes-Benz 1 07-01-2004 04:23 AM
Automatic transmission question: anyone knows how to make the transmission shift at a higher RPM, DanPro1 R170 SLK Class 8 10-07-2002 02:35 PM
Prefacelift SLK: shift-knobs for automatic transmission can be installed on manual transmission? Marcello (Piacenza - R170 SLK Class 3 04-26-2002 11:05 AM
