» Site Navigation
» Other Sites
Old 09-11-2006, 09:51 PM   #21 (permalink)
Date registered: Sep 2006
Vehicle: 1993 W201 2.6
Send a message via AIM to DarkCreep
Im going to my work to return some Digi cam I bought and I will get the kit. Thanks a lot man! Is a 1000w kit ok?
DarkCreep is offline   Reply With Quote
Old 09-11-2006, 10:04 PM   #22 (permalink)
w201 Über Moderator
Kynyption's Avatar
Date registered: Jan 2006
Vehicle: 1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
Send a message via ICQ to Kynyption Send a message via AIM to Kynyption Send a message via MSN to Kynyption Send a message via Yahoo to Kynyption Send a message via Skype™ to Kynyption
How much you paying. Walmart sells a 1400w kit for like 40USd and a 1600w kit with a Cap. for like 80. I got both of them for my car and they work fine.
You Can Find Me In The w201...
...Don't Forget to Add Yourself To The w201 Frappr map!...
...Coming soon Projekt Euro
Kynyption is online now   Reply With Quote
Old 09-12-2006, 08:43 AM   #23 (permalink)
I work at Fry's Electronics and im going to see if I get a good discount for the kit there....
I'll be back soon!
Oh and I also need to pick up an upper radiator hose because mine started cracking and I cut the end and pulled it towards the outlet. Its being stretched out but it needs to be replaced. :\ Also, my radiotor pulley, I believe, needs new bearings. The car is real loud from the front.
Old 09-13-2006, 11:41 PM   #24 (permalink)
Whatsup? I picked up two amp kits today at work.
One is a Monster 300 series (1000w) and it comes with
4 GAUGE 22Ft of cable.
8 gauge ground cable 5 feet.
8 gauge power cable 5 feet
Remote turn on cable 16 feet
Inline midi fuse holder with 100amp MiDI fuse
four black nickel amplifier barrier and 8 mini spades
monster crimpless 4 gauge ringer terminals
two monsters crimpable 8 gauge ring terminals.
It says its only to connect multiple amps and subs.
The next one was a generic one that was also for 1000w systems. It came with.
-20 ft 8 gauge RED power wire
-4 ft. 8 gauge BLACK ground wire
-20 ft 16 gauge BLUE remote turn on.
-20 ft 12 gauge Speaker Wire
-RCA interconnect audio cable, 20 ft right angle
-split loom
-gold plated fuse, 60amps
and other accessories like spade terminals, ring terminals. butt connecters. cable ties and black grommets.
I bought both because I didn't know which would be better, I knew monster would be better but the $20 came with more stuff and speaker cable.
What do I do now? lol...
I only want to connect one 12" Boston woofer to a 1000w Kenwood amp. More details tomorrow as I haven't picked up the amp from my dad's shop.
Old 09-14-2006, 05:46 AM   #25 (permalink)
Date registered: Jul 2005
the answer is upto you
do you ever plan on adding another amp?
if not the generic kit is all that you need.
at one time i had 3 amps in the back of my 190, but after the cops let me know that they didnt like i i took them out.
now i just have one amp and one sub
bshackelford711 is offline   Reply With Quote
Old 09-14-2006, 11:12 PM   #26 (permalink)
Why can't you have 3 amps?
I got the Monster for $60 and the Generic for $12.
Old 09-14-2006, 11:42 PM   #27 (permalink)
I got this amp, A Kenwood KAC-929.
Key Features:
GENERAL FEATURES
- Ground Isolation Circuit
- Low-Pass Electronic Crossover
- Power MOSFET Switching Power Supply
- Stereo, Mono, or Tri-Mode Operation
- Variable Low-Pass Electronic Crossover: 50Hz - 200Hz, 18dB per Octave
POWER RATINGS
- Bridged Power Output at 14.4V (1kHz, 0.8% THD): 460 Watts x 1
- Maximum Output Power: 1000 Watts
- Power Output at 2 Ohms, at 14.4V (1kHz, 0.8% THD): 230 Watts x 2
- Power Output at 4 Ohms, at 14.4V (20Hz-20kHz, 0.08% THD): 150 Watts x 2
AUDIO FEATURES
- Quiet Turn-On
- RCA Audio Inputs: Gold-Plated
- Speaker Connectors: Gold-Plated, Screw-Type
- Speaker Level Input Terminals
- Speaker Relay Protection
POWER SUPPLY FEATURES
- 2-Ohm Stable
- Black Powder-Coated Top Cover: with Sandblast Finish
- Copper EE-Core Power Transformer
- Large Aluminum ID Badge
- Noise Supression Filter: 3
- Power Indicator: Blue
- Power Input Terminals: Gold-Plated, Large Screw-Type
- Secondary Capacitors: 2 Large
AMPLIFIER FEATURES
- 2 or 1 Channels of Amplification
- Cooling Fan
I came to find out its a pretty good budget amp from the reviews ive read.
Now as to connect this up,
Old 09-15-2006, 05:57 AM   #28 (permalink)
because when i got stopped at a local store here and he let me know that i was rattling his windows he wasnt very happy.
that was cool to me until he showed me how well he could write, and let me leave with a pink slip of paper.
after the fine and everything i just left them in for a while and then it just got to be to much for me so i cut it back to one amp and one speaker.
Old 09-15-2006, 05:58 AM   #29 (permalink)
how much are you going to spend on this amp?
have you compared it to some of the others on the market?
Old 09-15-2006, 01:57 PM   #30 (permalink)
The amp is payed for.
It was given to me by my dad.
add mp3 player on MB 7006 car radio gsm-decode R129 SL Class 0 07-01-2006 12:19 AM
Any aftermarket or custom gauge add-ons available? OrangeMarlin W203 C-Class 8 01-04-2006 05:33 PM
Can I add other radio to my stock radio?(2002 CLK320) Guest (MBNZ) Audio & Telematics Forum 2 02-13-2002 07:04 PM
Can I add other radio to my stock radio?(2002 CLK320) Kuyman W208 CLK Class 0 02-10-2002 11:35 PM
It is possible to add aftermarket cd changer with stock radio(2002 CLK)?. Guest (MBNZ) Audio & Telematics Forum 2 01-13-2002 05:54 PM
