» Site Navigation
» Other Sites
Old 09-11-2006, 02:10 PM   #11 (permalink)
w201 Über Moderator
Kynyption's Avatar
Date registered: Jan 2006
Vehicle: 1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
Send a message via ICQ to Kynyption Send a message via AIM to Kynyption Send a message via MSN to Kynyption Send a message via Yahoo to Kynyption Send a message via Skype™ to Kynyption
Yeah...you're going to want to untwist those....haha
You Can Find Me In The w201...
...Don't Forget to Add Yourself To The w201 Frappr map!...
...Coming soon Projekt Euro
Kynyption is offline   Reply With Quote
Old 09-11-2006, 02:30 PM   #12 (permalink)
w201 Über Moderator
Kynyption's Avatar
Originally Posted by DarkCreep
Wow.... Kynyption you really help! You dont know how much I appreciate this.
On the harness, these are the colors
-White/Black - Driver Side Front (+)
-White - Driver Side Front (-)
-Green/Black - Driver Side Rear (+)
-Green - Driver Side Rear (-)
-Grey/Black - Passenger Side Front (+)
-Grey - Passenger Side Front (-)
-Purple/Black - Passenger Side Rear (+)
-Purple - Passenger Side Rear (-)
-Black - Ground
-Red - ACC (Switched)
-Yellow - Battery (Constant)
-Blue - Power Antenna..(remote lead)
-Blue/White - (Unsure)
For some unknown reason to me, the red and yellow cables are twisted together.
First thing i want you to do if you can is take a picture of the wires you have.
Do you have these connected to your speaker wires
There should be 4 of them, one for each speaker.
Old 09-11-2006, 03:02 PM   #13 (permalink)
Date registered: Sep 2006
Vehicle: 1993 W201 2.6
Send a message via AIM to DarkCreep
Removed the electrical tape.
Closer shot of the colors.
The stereo removed.
I only have two... Not 4.
Another shot of the back, hope it helps.
Rear shot of the head unit, Like if it even helps.
Did this help any Kiny?
DarkCreep is offline   Reply With Quote
Old 09-11-2006, 03:11 PM   #14 (permalink)
w201 Über Moderator
Kynyption's Avatar
Hrmm. Two..Interesting. And you have 4 speakers? Hrmm maybe you don't have a Front/Rear fading option because they are spliced together...Im not too sure. You said you are going to be running new wires anyway right?
The harness looks great after removing the wires and stuff. In the post above i bolded which wires go where. If you do choose to run new speaker wire then you wont have the problem of locating where the hell all your cables are. lol.
on that Headunit is that a CD Changer that you have plugged into it or Sat. Radio? Just curious.
The adapter housing that your holding in your left hand in some pictures, do you have the piece that connects to it from the OEM unit? It will be easier to connect that and splice into the other piece than rip off that cover. Because that section is where you will connect your ACC/ Constant Power/and Ground wire.
Old 09-11-2006, 03:27 PM   #15 (permalink)
andy.cowman's Avatar
Vehicle: 190E 2.0 Auto
Send a message via MSN to andy.cowman
You seem to have it pretty well together! ANyway the red and yellow power cables would have been spliced together to mean that the radio can be used with out needing the keys in the ignition and also because someone was to lazy to give its own constant feed to maintain radio memory settings when the keys were out of the ignition! Halfords in the UK use that trick when they "fit" your radio!
Andy
*Its amazing how a 20 year old mercedes is more reliable than a 10 year old landrover*
http://www.andycowman.co.uk
http://www.teamcannonball.co.uk
andy.cowman is offline   Reply With Quote
Old 09-11-2006, 03:42 PM   #16 (permalink)
The HU is not a Sat, it is just a CD player.
I do have the fading option next to the gear shift.
Actually, its 6 speakers bringing the 2 subs into play, but really its 4 because they are dead.
I will be running new speaker wire.. So all I do is
1: remove the speaker
2: connect new wire to it.
3: run it to the HU just like its stated and the diagram
4: do that to each speaker
and Voila?
Old 09-11-2006, 03:51 PM   #17 (permalink)
Andy
Interesting! I learned something today. So when I rewire the stereo, I do that again?
Kryp, thank you for all the help. I will be picking up some speaker wire tomorrow. Should I just get an amp kit because Im getting a Kenwood 1000w amp (dunno about the 2 or 4 ch though )and I have a single 12" Boston Generator woofer that I plan on getting connected. Would it be really hard to do this or can it be a DIY?
YOU GUYS ROCK!!!
Old 09-11-2006, 04:10 PM   #18 (permalink)
w201 Über Moderator
Kynyption's Avatar
You may as well pick up an amp connector kit as well. I can help you through the subwoofer install as well I've installed two 12" in the trunk. If you need any help Call my cell, easier to talk and I can visually inspect and walk you through. (Verizon Calls Free) (808) 341 0723.
Old 09-11-2006, 06:39 PM   #19 (permalink)
I can install the subs myself with very little previous knowledge? woah.. can't wait to try this!
How did you know I have VZW btw?
Old 09-11-2006, 07:50 PM   #20 (permalink)
w201 Über Moderator
Kynyption's Avatar
Yes you can. With help. Or you can read the instructions, but thats a bitch. Where as you can ask people who actually own the car you have.
I work in mysterious ways.
AND You Know What, I fucked Up My number its (808)341-0723 not 809 haha. sorry about that.
add mp3 player on MB 7006 car radio gsm-decode R129 SL Class 0 07-01-2006 12:19 AM
Any aftermarket or custom gauge add-ons available? OrangeMarlin W203 C-Class 8 01-04-2006 05:33 PM
Can I add other radio to my stock radio?(2002 CLK320) Guest (MBNZ) Audio & Telematics Forum 2 02-13-2002 07:04 PM
Can I add other radio to my stock radio?(2002 CLK320) Kuyman W208 CLK Class 0 02-10-2002 11:35 PM
It is possible to add aftermarket cd changer with stock radio(2002 CLK)?. Guest (MBNZ) Audio & Telematics Forum 2 01-13-2002 05:54 PM
