» Site Navigation
» Other Sites
Old 08-21-2006, 11:09 AM   #1 (permalink)
Reverse works sometimes?
I have a 92 2.3 auto and the reverse is wierd. There's a long pause before kicking into reverse and then it only works at idle, just enough to move on a flat surface or decline. If I give it gas it just rev's up. It feels like it's not building pressure up. But if I start on a hill, shift into reverse, and let it roll for 10 feet backwards in reverse I can feel it kick in then it's normal again and It's full speed in reverse. It will stay normal again for a few miles. It's like a valve is sticking or broken spring in the valve body. Just wondering if anyone else had this problem.
jafo1994 is offline   Reply With Quote
Old 08-21-2006, 12:04 PM   #2 (permalink)
hyprr1's Avatar
Vehicle: 1995 C36 AMG, 2006 Honda CR-V, 1993 190E 2.3L (Greece)
Send a message via MSN to hyprr1
I'm not 100% sure, but this could be your vacuum modulator. The VM is on the
pass. side of your transmission & it could be disconnected or malfunctioning.
Spiros "hyprr1"
hyprr1 is offline   Reply With Quote
Now all works....... ZĂ© Bocaina G-Class 12 09-03-2006 02:06 PM
Every works, except mansito W126 S,SE,SEC,SEL,SD,SDL Class 7 05-10-2006 06:02 PM
Reverse Exterior Light don't works casimiro W168 A-Class 0 03-30-2006 09:24 AM
does it really works? 430convertible W208 CLK Class 2 02-16-2006 12:05 PM
1995 S320 reverse GRINDS, forward works fine......whats the problem??? artemmartinov W140 S-Class 7 07-28-2005 11:29 AM
