» Site Navigation
» Other Sites
Old 07-29-2006, 06:23 PM   #1 (permalink)
Date registered: Jun 2006
Vehicle: 1984 190E 2.3
2.3L 4cyl. piston location...
Ok I know the firing order is 1342.
My question is the #1 cylinder on the front of the engine (towards the grill) or the rear? Thanks.
Dracus is offline   Reply With Quote
Old 07-29-2006, 08:15 PM   #2 (permalink)
Jammerkiller's Avatar
Date registered: Jul 2005
Vehicle: 1991 300SE, 1987 2.3-16
In the front, towards the grille. Almost all in-line engines are labeled starting with the front (or first) cylinder being #1. Unless you're working on an older piston-driven prop plane.
"Imagination is more important than knowledge"
Jammerkiller is offline   Reply With Quote
Old 07-29-2006, 08:45 PM   #3 (permalink)
Ok thanks.
It's just weird because the spark plug wire holder says "1342" but the way its arranged it appears that #1 is towards the firewall.
Old 07-30-2006, 11:29 AM   #4 (permalink)
I see. Also, the distributor cap should have an indicator, or a "#1" marked on it for the first cylinder. you could pop off the cap and rotate the engine until the rotor is pointing towards said indicator, then trace that wire to the spark plug. That's #1.
Old 07-30-2006, 02:30 PM   #5 (permalink)
Hey thanks for your help. I got it all sorted out now....finally.
1975 230 4CYL "GAS" NEED TO kNOW bad!!!!!! nineofthem Vintage Mercedes-Benz 1 08-06-2005 09:39 AM
1975 230 mercedes 4cyl gas VDO part nineofthem Vintage Mercedes-Benz 0 08-06-2005 05:38 AM
230 4cyl gas 1975 nineofthem Vintage Mercedes-Benz 1 08-04-2005 11:06 PM
MD 4cyl diesel transplant to '82 Jeep Scrambler RoyH W123 E,CE,D,CD,TD,TE Class 1 08-15-2004 09:41 AM
Engine management problem 93 W124 220E 4cyl. Guest (MBNZ) W124 E,CE,D,TD Class 3 12-05-2001 10:44 PM
