Old 07-02-2006, 01:50 PM   #1 (permalink)
1993MB190E's Avatar
Vehicle: 1993 Mercedes Benz 190E 2.3
Send a message via AIM to 1993MB190E Send a message via MSN to 1993MB190E
Question Oil Pressure loss with AC on and stopped.
I have a few problems that keep bothering me...My AC was just recharged a month or so ago. Well sometimes the AC just shuts off on its own, then there are other times when it works perfectly. I have no idea where to start with this problem. Another question I have for all of you is, When I'm stopped at a light, with my AC on, the oil pressure drops half way down the guage, is that normal? But when I start driving again it goes back up to normal. If you know anything about these problems please let me know! I appreciate the help, Thanks in advance, Mike!
1993MB190E is offline   Reply With Quote
Old 07-02-2006, 10:16 PM   #2 (permalink)
Vehicle: 1991 190e 2.3, 1981 300D Euro, 1998 BMW 328i
If the AC is intermittant, I would start first with the compressor & look at it to see if the clutch is engaging. The compressor could be shutting down because of an over/under pressure in the system (usually the black switch on the dryer) or a high engine operating temp (usually the blue switch on the engine coolant block) It could also be a problem with the climate control unit in the dash. As far as the drop in oil pressure, it may just be the lower RPM's at idle when the AC is on. I think half way down the gauge is OK. Good Luck......
jmas2k is offline   Reply With Quote
