» Site Navigation » Other Sites
» Network Links
05-28-2007, 05:19 AM
#11 (permalink )
Date registered: Jan 2007
Vehicle: 93 190E 2.3
it looks like it is
this item
05-28-2007, 01:38 PM
#12 (permalink )
Date registered: Jul 2006
Vehicle: Mercedes 190E 2.0L - 1986(black with grey)
That fitting I don't think it needs to be replaced. A good cleaning will do the job. I my case has made miracles.
But have a look here:
http://www.fuel-pumps-and-filters.co...3769919oes.jpg
05-28-2007, 03:23 PM
#13 (permalink )
Originally Posted by tavioman
it is exactly the same item i just mentioned
05-28-2007, 09:45 PM
#14 (permalink )
Vehicle: Dodge Caravan 3.0 2000 / Mercedes 190E 2.0 1983 / Dacia 1310 TLE 1.4 1990
Mercedes 190 E 2.0 (1983) 102.961 engine
"In giving advice, seek to help, not please your friend. " - Solon (638-559 BC) Greek lawgiver & politician.
05-28-2007, 10:33 PM
#15 (permalink )
Date registered: Sep 2005
Vehicle: White 1988 190E 2.3 196,000 mi
Any special precautions before unscrewing it or is it simple job?
You'll Never walk Alone
05-29-2007, 12:01 AM
#16 (permalink )
It has a seal ring (part number: N 007603 012110) on the distributor side, careful on that or replace it.
05-29-2007, 12:40 AM
#17 (permalink )
I'm sorry that I din't made any pictures of mine to see how clogged up was. I just blow some compressed air in it and everything was fine again.
05-29-2007, 01:25 AM
#18 (permalink )
I think I'll try that...
05-29-2007, 04:16 PM
#19 (permalink )
I tried it without an air compressor, cleaned it out got no change. My mechanic said i had low compression all around (90-100 psi) and lower when warm and he thinks that is why i have starting issues especially when warm. Theory is either the rings or the valves. Also the benz cuts out when slowing down every once in a while so i was hoping to fix it without having to buy an idle speed valve. (which my mech said i needed)
05-30-2007, 05:35 PM
#20 (permalink )
Vehicle: 1996 Volvo 855 GLT, 1993 Mercedes-Benz 190e 2.3 8v
how do you test the maf to see if its going bad? im gonna look into it but using a volt meter how do u tell if its lean or rich? my car feels lean. wish i had the manuals here wit me
Jippi Jak
1993 MB 190E 2.3---Car's naked...
1996 Volvo 855 GLT--Project R clone Benzworld.org---Jersey Crew
Thread Tools Display Modes Linear Mode
