» Site Navigation
» Other Sites
Old 03-21-2006, 04:51 AM   #1 (permalink)
Date registered: Feb 2006
Vehicle: 1985 190E 2.3
power steering fluid leak
Well, I have isolated a p/s leak at the high pressure connection to the pump. Thought I might try to tighten the connection but do not want to break anything.
Do I need to replace the entire hose section?
Thanks, James
jas322 is offline   Reply With Quote
Old 03-23-2006, 01:20 PM   #2 (permalink)
Date registered: Aug 2005
Vehicle: 1986 190
RE: power steering fluid leak
I wouldn't have thought so, my friend, got a leak on mine too, not going to replace any hoses..
muttley is offline   Reply With Quote
Old 03-26-2006, 06:03 PM   #3 (permalink)
red_benz's Avatar
Date registered: Oct 2005
Vehicle: 190e 2.3 widebody
suggest you buy a single hex open ring spanner, called a flare nut spanner, using this you can tighten the coupling tighter than with a regular spanner. i bought a cheap flarenut spanner and cut some length off so it would fit in the space to tighten mine. seems to be a common problem with 190e's. check for leaks after tightening to see if hose end or coupling has a crack causing the leak, hjopefully you will get lucky and just nip up the nut to fix the leak
red_benz is offline   Reply With Quote
Old 03-28-2006, 03:28 AM   #4 (permalink)
Thanks quys. I will see if I can put a little more torque on this connection.
Appears to be the only fluid leak on this car and it's a good one.
