LOOKS VERY, VERY VERY VERY NICE.
I DID THE SAME ON MY 1990 190 2.6 AND THE FRONT TIRES ARE TOUCHING THE BUMPERS.
DID YOU DO ANY UPGRADE TO THE SUSPENSION SUCH AS NEW COIL OR SHOCK ABSORBER AS YOU CHANGE THE RINGS???
Vehicle: 1997 Dinan BMW M3; 1985 190e 2.3, 2002 Land Rover Freelander
RE: New Wheels 2/20/06 **Pics**
MBUSER - 2/22/2006 8:34 PM
I WILL THANK YOU IN ADVANCE FOR YOUR HELP..
I didn't touch the suspension and today I was going down some hills and heard a rubbin of metal so I may need ot have it aligned, if thats not the problem then I don't know what it is.
MBUSER - 2/23/2006 6:17 AM
Could you ask what they did for the gap???
Thanks in advance
Ask who did what? I think you are referring to the wheel gap, which if you are the new tires does remmove a little portion of that gap, I installed the new tires/wheels myself
Yal - 2/23/2006 10:29 AM
Have you done an alignment yet?
No, but it came to mind that it may have something to do with it, but I am not sure.
What do you think?
It sounds like metal on metal, I relate to to the brake pad being shot and the rotor is rubbing the caliper, but it was just inspected this month and the brake wear was fine.
RDM3 - 2/23/2006 11:00 AM
Also, when you are goign down the hill pressure is being force on the front wheels so when you hit the bottom of the hill and start to go up the rubbing happens, then once you are going back up the pressure is gone, it is an up down up down hill sequence, it is a small hill.
What do you think?
