Old 02-17-2006, 11:52 AM   #1 (permalink)
Date registered: Feb 2006
86 190e 2.3 fuel delivery problems
When I bought this car a couple of weeks ago the AFM was rigged open. I replaced the AFM with a used unit with no luck. I've since replaced the fuel distributer, and idle valve (both had been beaten on by the previous owner) with used units. I also put in a used coolant temp sensor.The fuel pressure regulator looks to have been recently replace with a new unit. If i disconnect the fuel line and turn the igition on, fuel pumps into a catch can at a decent rate, but I have no way of checking the pressure. The vehicle has a half tank of gas. I've removed and cleaned all of the injectores with compressed air.
If I poor fuel into the AFM/throttlebody, the car will fire up, and idle well until the supplimental fuel runs out. Sometimes I can keep it running by massaging the pedal, but it runs like crap.
any suggestions would be appreciated!
I would also sell the car if anyone wants it. It's in Indianapolis. check the classified on this site.
reggiestewart is offline   Reply With Quote
Old 02-17-2006, 01:17 PM   #2 (permalink)
RE: 86 190e 2.3 fuel delivery problems
Here's a link to my classified ad for this car on this site:
http://www.benzworld.org/forums/foru...posts=2&fid=56
Thanks!
Old 02-17-2006, 01:36 PM   #3 (permalink)
DAN57's Avatar
Date registered: Jan 2006
Vehicle: 190E 3.0
Where did you check fuel delivery? I think maybe it's worth trying disconnecting fuel lines from your checkpoint along the line to the injectors. This should at least show up where the fuel flow is being resricted.
DAN57 is offline   Reply With Quote
Old 02-20-2006, 01:53 PM   #4 (permalink)
I got it running! The only problem is that I'm not 100% sure how.
1. I disconnected the battery to reset the computer. (I had installed the new components mentioned above without doing this.)
2. I switched AFM's one last time
3. I checked my idle valve connections again.
4. The used fuel distributor that I bought smelled like varnish, like it had been sitting for some time, so I blew it out with compressed air.
Can anyone eliminate one or more of these items from being the solution? My main goal is to re-sell one or more of my spare AFM's, but want to make sure that they are not problematic. I guess I could re-install each of them to check them, but it seems like there would be a better way to tell.
Also, the car idles extremely high, around 2000-2400 RPM's. Any suggestions?
Old 02-20-2006, 07:33 PM   #5 (permalink)
Yal
Date registered: Sep 2004
Did you adjust the fuel air mixture each time?
Yal is offline   Reply With Quote
Old 02-20-2006, 08:11 PM   #6 (permalink)
no, not directly, but the different AFM could have been set differently. I never touched the settings. The latest AFM has what appears to be a screw broken off in the top of the rich/lean adjust shaft. I could probably get it out w/ either a dremel or drill if necessary.
Old 02-21-2006, 06:44 AM   #7 (permalink)
Yal
Here you go... http://www.landiss.com/mixture.htm
Everytime you mess with the fuel and air delivery you wat to adjust the mixture to get things back in spec.
