Old 02-17-2006, 12:01 PM   #21 (permalink)
Syracuse315's Avatar
Date registered: Jan 2005
Vehicle: '86 190E 2.3L
RE: wadeperformanceproducts.com??
I think I'm going to fabricate one in a day or two, I'll post a pic and let you guys have a look. I'm probably going to use the multiple tube idea..anything wrong w/ that idea, I can't think of anything right now...
If it jams, force it. If it breaks, it needed replacing anyway.
1986 190E 2.3L 135,000mi
Syracuse315 is offline   Reply With Quote
Old 02-17-2006, 12:39 PM   #22 (permalink)
AMGBenz91's Avatar
Date registered: Feb 2006
Vehicle: 1991 190E 2.6
I might just want to try and open up the OEM intake openning like you mentioned and try to get more air routed into it. the 2.6 has barely enough room to do anything. And it seems like the opening of the intake ducting is so thin. Somehow it must suck air in from the left side of the radiator. In the pics you can see how there is almost no room for a bigger intake nozzle. Even if there was an aftermarket cold-air intake on a 2.6 there would be a minimal amount of air rushing in that little space to begin with, so in all the OEM setup is probably the best thing for it, unless you would be able to route the air in from another opening in front of the car.
AMGBenz91 is offline   Reply With Quote
Old 02-17-2006, 12:47 PM   #23 (permalink)
SDR
SDR's Avatar
Date registered: Sep 2005
Vehicle: '99 C43
Syracuse315 - 2/17/2006 2:01 PM
Avoid dragging a tube from the exhaust side and over the valve cover unless you want to pre-heat the air :)
I've seen some guys that have done away with the fog lights. If you don't have the Euro style headlights you could customize a matched replacement cover and make the drivers side an addtional opening :)
SDR is offline   Reply With Quote
Old 02-17-2006, 12:55 PM   #24 (permalink)
AMGBenz91's Avatar
does anybody know of a good website online where you can buy the intake tubing for a 2.6. One the the connector ducts near the air box has a crack in it that i want to replace.
Old 02-17-2006, 01:11 PM   #25 (permalink)
hood scoop?
Old 02-17-2006, 08:09 PM   #26 (permalink)
AMGBenz91's Avatar
not a hood scoop...just one of the duct pieces that routes the cool air from the front to the air box. Does anyone know where i could get a replacement part for that.
Old 05-06-2006, 12:18 AM   #27 (permalink)
Vehicle: 1992 190e 2.6
Originally Posted by SDR
It's a 2.6 engine.
I picked up the Stage 1B for $155. It includes all the connections as opposed to some of the other models.
I'd let it go for $100 shipped.
If you still got it ill take it!!!
MASTERBLASTER is offline   Reply With Quote
Old 12-12-2007, 01:00 PM   #28 (permalink)
Date registered: Oct 2007
Vehicle: 1984 Mercedes-Benz 190E 2.3L Chassis:201.024 Engine:102.961
if i would like to have that vrrooomm sound of aftermarket intakes when i hit the gas....
how is the wade for sound??
chupowei.
1984
Mercedes-Benz
190E
2.3 L4
Chassis 201.024
Engine 102.961
chupowei is offline   Reply With Quote
Old 12-12-2007, 11:58 PM   #29 (permalink)
JamesDean's Avatar
Vehicle: 93 190E 2.6; 82 300 SD Turbo
Send a message via ICQ to JamesDean Send a message via AIM to JamesDean Send a message via MSN to JamesDean Send a message via Yahoo to JamesDean
this might be a bit extreme but what if you were to create a "port" right above the driver headlamp in the hood of the 2.6 kind of like a ram air effect.....i dno how that would work entirely.
I've seen some people do like a vent in the fender, im told some 190D's had them.
I agree the 2.6 is quite limited in the area up there, they really shoe-horned the engine in there.
Perhaps with some serious modification one could install duct work so that the air is drawn up from behind the bumper on the driver side. Either cut through the sheet metal or somehow run it underneath the intake manifold.
::shrugs::
"The past tempts us, the present confuses us and the future frightens us...and our lives slip away moment by moment lost in that vast terrible inbetween."
JamesDean59 - AIM
JamesDean59@gmail.com
thebenz300SD - YAHOO
195388464 - ICQ
1982 - 300SD 135,000 (needs rear window resealed)
1982 - 300SD 243,000 (needs better seats!)
1990 - 300SE 260,000 (restoring)
1993 - 190E 2.6 210,050 (waiting for lower core support repair)
JamesDean is offline   Reply With Quote
