Old 01-24-2006, 05:50 PM   #11 (permalink)
Vehicle: 92 190E 2.6L
Send a message via AIM to jessfx
RE: How to pull code for CEL?
^bump
jessfx is offline   Reply With Quote
Old 01-26-2006, 11:26 PM   #12 (permalink)
theairboy's Avatar
Date registered: Jul 2004
jessfx
Sorry ben working a ton of overtime these days.
That sucks your not getting a sinal the the test plug.
Have you tested all the fueses with a volt meter on the fues tabs?
The info that is sent to that plug comes from the ECU.
There are some other ways to test that plug I've heard , but never had to do it. Look for damage to the wire harness by the plug in the battery area.
It may be taking you beond the DIY thing and require a Bosch tester to be hooked up between the ECU and the ECU outlet plug. The reson I say that is to determin if the ECU is even sending the signal. You would need to find the corect wires on the plug and 1 tell the ECU to run the self diag. and 2 monitor the voltage spikes to decifer the codes. Paying to have the Bosch tester installed is a lot easer.
300E M104
190 16V
theairboy is offline   Reply With Quote
Old 08-03-2007, 09:48 PM   #13 (permalink)
Date registered: Jan 2006
Vehicle: 1992 2.3 190E
I just printed out Airboys code chart. I had seen the chart before and managed to get mine to blink before but it was fussy. I had never seen the trick of the 3 and 8 second hold and release.
Old thread but tks for posting. Now if I can just find out which Coolant Sensor is on the fritz, intermitent. I can clear it and it may go 5 mins or days. Leaning toward the 4 pin on the sensor block but I can't seem to find out even using the manual.
Dan
Logon_Bob is offline   Reply With Quote
