Old 03-14-2005, 05:04 PM   #1 (permalink)
1984 190D
Please help.
My 84 190D 2.2 automatic in 4th gears at 60mph 3000rpm.
When I shift to 3rd it revs even hire.
Is that correct, ore do I have a problem.
No glow light on dashboard.
I can get it to light up if I play with ignition switch back and
forth. Still no working, I have to use starting fluid to start it.
Replaced glow plug relay still the same problem.
Dose it have sensor to tell it when to work?
Ore I have to look some wear ales?
I appreciate awry ones help.
meren is offline   Reply With Quote
Old 03-16-2005, 02:14 AM   #2 (permalink)
rib
Date registered: Apr 2004
Vehicle: s320, 230ce
Send a message via MSN to rib
RE: 1984 190D
using starting fluid is bad, check and replace all glowplugs if needed, start with that. my 2.5 is about 2,800 rpm at 60 so with a 2.2 that sounds about right
'83 240TD- 218,000miles - SOLD
'91 190D 2.5- 217,000miles -SOLD
'87 300d- 160,000miles -SOLD
'96 s320- 95,000miles- sold
'90 230ce-170,000miles
'87 190e 2.3-16 - 65,000 miles
rib is offline   Reply With Quote
Old 04-21-2005, 03:55 PM   #3 (permalink)
Date registered: Apr 2005
Vehicle: '86 190E 2.3 8vlv
RE: 1984 190D
Sounds like you figured it out already but didn't realize it....
You said that the glow plug comes on if you jiggle the ignition switch.
If so, it is probably the ignition switch. The part is cheap, but a little frustrating to install...you have to remove the instrument cluster and it is sort-of accessible behind that.
I don't know exactly, but my mechanic did it for me, and I also read about it on a forum after mine was done.
Let us know how it goes.
Joe
joebob2 is offline   Reply With Quote
Old 04-21-2005, 09:26 PM   #4 (permalink)
mfagus's Avatar
Date registered: Nov 2004
Vehicle: 1987 TD Wagon & 1992 190 Sportline
Send a message via Yahoo to mfagus
RE: 1984 190D
I have a 1984 190D with a 5 speed. Driving at 70 MPH I am sitting right at 3000 RPM.
mfagus is offline   Reply With Quote
Old 04-25-2005, 11:37 AM   #5 (permalink)
Axel F's Avatar
Date registered: Mar 2004
Vehicle: w201 190D
RE: 1984 190D
normaly changing the ignition lock is pretty simple
look at this
http://www.geocities.com/shvoldum/owners/locks.html
http://users.skynet.be/fa782220/voiture/index1.htm
Axel F is offline   Reply With Quote
