Old 12-14-2004, 06:27 PM   #1 (permalink)
Date registered: Dec 2004
Flex Disk Replacement
Help,,,,I had the front flex disk go out in my 86 190E, my local mechanic replaced the disk, now I have a vibration going about 35-45mph. Any help would be greatly appreciated.
MBowerson is offline   Reply With Quote
Old 12-14-2004, 06:44 PM   #2 (permalink)
slk230red's Avatar
Date registered: Mar 2004
Vehicle: '01 SLK230,'93 190E 2.3
RE: Flex Disk Replacement
MBowerson - 12/14/2004 8:27 PM
Go back and read the replies to your 12/11/04 post. "theairboy" mentioned that the two piece drive shaft must be put back in the same position so it doesn't go out of balance. That could result in your car having a vibration.
I replaced the front flex disk on my '93 190E about a year ago and everything went smooth and I did not have to remove the drive shaft. It sounds like something wasn't reconnected properly. It's hard to tell without raising the car to inspect. Did you take the car back to your mechanic to have him re-check his work? I would do that first and ask him exactly what components he removed from your car to replace the front flex disk.
Good Luck and keep us posted on the outcome.
Dave
slk230red is offline   Reply With Quote
Old 12-14-2004, 07:14 PM   #3 (permalink)
I appreciate the info. I am betting he removed the shaft, and did not replace as removed. What does it take to have the shaft balanced??
Old 12-16-2004, 07:30 PM   #4 (permalink)
Date registered: Oct 2002
I should not cost to much to get it balanced, but the problem is its hard to find anyone that can do it. At least where i live. I had to goto drive line services of portland, since they where the only ones that had a clue.
Maxh is offline   Reply With Quote
Old 12-17-2004, 02:40 PM   #5 (permalink)
osdesierto's Avatar
Date registered: Oct 2004
Vehicle: W201, W202, W210, E53
Send a message via AIM to osdesierto Send a message via Yahoo to osdesierto
Go back to your mechanic and have it checked... you shouldn't have to pay anything.
osdesierto is offline   Reply With Quote
Old 07-04-2007, 12:12 PM   #6 (permalink)
I just acquired a '91 190e. It runs smoothly until 45 then has some fairly violent shaking. At 60, it is a dull roar coming from the rear. My first analysis was a U-joint but I am gathering that the car must not have a u-joint but a flex disk. Would this behavior indicate a flex disk problem? any ideas?
ejessee is offline   Reply With Quote
Old 07-04-2007, 12:27 PM   #7 (permalink)
w201 Über Moderator
Kynyption's Avatar
Date registered: Jan 2006
Vehicle: 1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
Send a message via ICQ to Kynyption Send a message via AIM to Kynyption Send a message via MSN to Kynyption Send a message via Yahoo to Kynyption Send a message via Skype™ to Kynyption
Wheel Bearing....?
You Can Find Me In The w201...
...Don't Forget to Add Yourself To The w201 Frappr map!...
...Coming soon Projekt Euro
Kynyption is offline   Reply With Quote
Old 07-04-2007, 12:56 PM   #8 (permalink)
blue's Avatar
Vehicle: 86,91 190E,86 300E
Center support bearing
Check the center support bearing. It's rubber and probably shows wearing out around the same time as the flex discs. I replaced a driveshaft on my '86 190E with a junker that I had discs put on and I have no vibration or rumble. I might be lucky though.
My wife's '91 190E has a center bearing going out and it rumbles a bit between 40 and 60 mph on acceleration and then ceases to rumble on cruise.
memento mori
blue is offline   Reply With Quote
