I've got a 1993 2.3L. The climate system fan makes a lot of noise when the fan selector is set on III or max. The noise sounds like a playing card in the spokes of bicycle wheel. Sometimes there is some squeaking as well. I've got the manual on cd to take out the blower motor and troubleshoot it. Can anyone tell me what the problem might be? Should I expect to replace the blower motor? Any feedback is appreciated!
Squealing is the electric motor itself, when it squeals, it's getting close to needing a replacement. Sometimes oiling the bushing a little bit stops it for a bit but in general, take it as a sign it's going out.
THe card in the spokes sound, I have no idea what that means.
-Tubs
__________________ W124 Forum Host
1993 Mercedes-Benz 300E Arctic White over Palamino Leather
W124.032 Chassis M104.992 24V Engine
217 Horsepower @5500RPM
229lbs-ft Torque @3750RPM
Aftermarket Modifications
-TYC Euro-Spec Headlamps
-DEPO Clear turn signal indicators
-Kenwood KDC-217S CD Player AM/FM Tuner Headunit
-Chrome Exhaust Tips
-Auxiliary fog lights and driving lights
-Tinted windows: 22.7% on the back 5 and 33% on the front 2
( The noise sounds like a playing card in the spokes of bicycle wheel)
Sometimes when a small object gets into the defroster vent or air intake it works its way down into the blower housing and the blower cage rubs on it sometimes making that noise.
Lubracating the bushings is always a good idea and look for small object in there well your at it.
the blower motor is about to die....the bearings are worn out, that is why the squealing and ticking sounds occur.
Yep if you are able to replace it yourself, please do. Saves you a lot of cash.
part is only available at dealerships, is about
US 200.00 - 230.00.
good luck
“One who conquers himself is greater than another who conquers a thousand times a thousand on the battlefield.”
