Jippi Jak
Totaled 6-27-05: 1985 MB 190e 2.3
1987 MB 190e 2.3-- sold
1993 MB 190E 2.3---work in progress
1996 Volvo 855 GLT
I need a benz bad........
For the back I'd go at least for the 18mms rubber rear spring shims (I guess NAm cannot get the 24s) and also I'd work on that toe-out of the front wheels (it's RWD, front should be toe-in on specs, camber looks about ok on rear, but looks too much positive on the front, in my opinion all should be rethink and adjusted, but due to the mod of the car I'd suggest the civil way to do it on the RWDs, out on rear and a bit inner for the front wheels). Don't exceed 1.5.
Mercedes 190 E 2.0 (1983) 102.961 engine
"In giving advice, seek to help, not please your friend." - Solon (638-559 BC) Greek lawgiver & politician.
The rear wheels are front-warded. Rust or impact in the lower trunk area had spliced the spot welded sheets that support the rear dampers. Anyway, I'd recommend the rear sway bar eccentric adjustment or even better a 4 wheel alignment based on rear wheels following angle (I'm not implying that she's been rear ended but it gives me doubts).
