Old 11-21-2004, 12:51 PM   #1 (permalink)
Date registered: May 2004
Send a message via AIM to New_User
My 190E starts fine, but then it dies...
Ok Ive got a 190E 2.6 1989. I had a problem with the ignition just after I purchased it and was running an external starter button. Well, a few weeks ago the car randomly died after running for about 20 minutes. The car had not been run for a couple days prior to this. Since then, Ive changed the ignition. But, the problem remains. If cold, the car will start and run for 15-20 mins. Once it is warm, it dies, and cannot be started back up until it has cooled again. I think it may be a sensor? Anyone have this problem or know what I should do??
Thanks
New_User is offline   Reply With Quote
Old 11-21-2004, 04:05 PM   #2 (permalink)
Date registered: Jul 2004
Vehicle: 190e 2.0 litre Euro
RE: My 190E starts fine, but then it dies...
Will it run all at, even for a second very badly? Does the starter crank?
Mike.
mike65 is offline   Reply With Quote
Old 11-22-2004, 09:22 AM   #3 (permalink)
It will not start after it dies, it cranks over and all that fine. I just got a new battery also. After it cools down it will start fine and dies eventually again.[xx(]
Old 11-22-2004, 11:41 AM   #4 (permalink)
It might be the coolant (engine) temp sensor
http://www2.maximumautoparts.com/parts/parts1/maximumautoparts/wizard.jsp?year=1990&make=MB&model=190-E-005&category=C&part=Water+Temp.+Sensor&appEngines= _any
The fact it dies when hot as well as not starting when hot is curious. It suggests some sort of fuel starvation, maybe the ECU is getting duff information.
Does the engine idle gradually fall until the engine is "bucking"?
Mike.
Old 11-22-2004, 04:02 PM   #5 (permalink)
BenzWorld W126 & W201 Host
spanners's Avatar
Date registered: Feb 2003
Vehicle: 1988 420SE, 2002 C180 Kompressor, 200 ML320
Send a message via MSN to spanners
When it dies and won't restart, check if the fuel pump is buzzing when cranking. I suspect you have a bad fuel pump relay.
Work is the curse of the drinking class!
spanners is offline   Reply With Quote
Old 11-24-2004, 01:35 PM   #6 (permalink)
It doesnt buck before dying, just dies out.
Old 11-24-2004, 05:03 PM   #7 (permalink)
spanners's Avatar
It's still worth checking whether the pump is buzzing when the car won't start.
It could be any number of things from the crankshaft sensor to the ignition pack but it's best to check the easiest things first.
Also, is there a spark when the car won't start?
Old 11-27-2004, 04:50 PM   #8 (permalink)
Yup theres spark, and I didnt hear any fuel pump buzzing .
Old 01-20-2005, 04:02 PM   #9 (permalink)
Date registered: Jan 2005
Have a similar problem....I have had some bad gas, and fuel treatment helps, but it typically happens when the car has run about 10 minutes, but before it has reached full operating temp. The last time it happened turning left across traffic...[V]
Mine will restart in 5 - 10 minutes after lot's of heavy cranking and sputtering...feels like fuel starvation, but it may be even fuel saturation. Lots of unburnt fuel coming out exhaust when trying to restart.
Interesting that gas treatment helps...I am supecting a faulty check valve may not be allowing the fuel to return to tank. I have noticed a vacuum in the tank when adding fuel treatment at times like these...yes definitely a vacuum, not pressure. I have also played with the gas cap trying to be certain the valve is free. Am having the fuel system checked again tomorrow, after changing fuel distributor, fuel filter, and cleaning out the tank with a syphon in the last 6 months of fighting this problem.
MDE3 is offline   Reply With Quote
Old 01-20-2005, 04:47 PM   #10 (permalink)
The 190e fuel tank is designed to have a vacuume.
Mike.
