Old 09-01-2004, 06:48 PM   #1 (permalink)
Date registered: Aug 2004
Send a message via AIM to Black_Benz93
ABS light, and Idle problems...
hey, my ABS light is on in my car, almost all teh time, i dont think i see it go off, does anyone know what seems to be wrong, or does it stay on? Also my idle is a little messed up, it will idle, but it takes a few minutes for me to hold at 2000 rpms fopr it to keep at around 800-900 rpms, after that it will idle in park fine, but in reverse and drive it has trouble idle and will stall sometimes, most the time actually, any suggestions? Also when the car is on the road, and u slow to a stop the idle gets sluggish right while stopping, any suggestions there too? thanks in advance
Black_Benz93 is offline   Reply With Quote
Old 09-03-2004, 04:44 PM   #2 (permalink)
BenzWorld W126 & W201 Host
spanners's Avatar
Date registered: Feb 2003
Vehicle: 1988 420SE, 2002 C180 Kompressor, 200 ML320
Send a message via MSN to spanners
RE: ABS light, and Idle problems...
Sounds like the fuse in the Over Voltage Protection relay may have blown.
I think it is located behind the battery on W201's, but if I'm wrong, someone will put you right.
It is a silver relay with a clear plastic flip up lid. The fuse is inside the lid. Worth checking.
Work is the curse of the drinking class!
spanners is offline   Reply With Quote
Old 09-03-2004, 11:01 PM   #3 (permalink)
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
Correct…
http://www.benzworld.org/forums/forums/thread-view.asp?tid=553742&posts=2&hl=ovp+location
1991 300 SE (w126.024/M103.981) 140,000 miles
jdc1244 is offline   Reply With Quote
