Old 08-02-2004, 10:53 AM   #1 (permalink)
Date registered: Jul 2004
Send a message via Yahoo to prosby
1987 190 e 16 valve
car was running fine ,hit 100.000 miles and became very sluggish,especially going up hill.stalls at 40mphand takes its time up hill to reach 80 mph.please advise.thanks.
prosby is offline   Reply With Quote
Old 08-02-2004, 11:42 AM   #2 (permalink)
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280
RE: 1987 190 e 16 valve
Rather generic advice,but sounds like a fuel delivery problem. Trace the fuel systems from the fuel tank to the fuel injectors. Likely culprits, one of the dual fuel pumps might be marginal or failed, clogged fuel filter, or possible bad injector, but unlikely. On the electronic side, the fuel pump relay might be acting up or a problem with one of the intake temperature sensors.
MTI is offline   Reply With Quote
Old 08-02-2004, 03:15 PM   #3 (permalink)
Date registered: Nov 2002
Vehicle: 190e-2.3
So far all my rough idle and poor running problems were solved with Chevron Techron fuel treatment. Its available at Walmart and auto part stores also. It happened so often with my 190 2.3, I started adding 35ml to each tank and my car has been perfect for the last 2 years. The discription of your problem is a little vauge so what I suggest is put a bottle or 2 in the car and while your trying to fix your car and it might just clear it self up. Chevron Techron..no substitutes... I wish I had a 16v hot rod in my driveway. I think were assuming your maintaince as far as tune ups is up to date.
Ignatz is offline   Reply With Quote
