sunroof switch only works forward and aft (not up and down). sunroof can open and close but i can only guess when to let off on the switch and consequently sometimes i dont have a tight fit. replaced the switch with new one from performance products but did not cure the problem. anyone else have the same thing? where is the motor anyway? thanks
motor for the roof is located on the left rear quarter panel. you have to open the trunk and then open a cover and behind near the left side close to the wheel well you will find the motor
