kytrex - 7/22/2004 12:57 PM Hi,
"...Has anyone ever performed their own transmission fluid and filter change? Is it a difficult task? Also, what brand of transmission fluid was used to refill? Finally, does this sort of maintenance help with rough shifting? Thanks everyone for your help..." |
If you have never done this task before I strongly recommend that you pay someone to do it...
Especialy if they allow you to watch and ask questions...
DO IT YOURSELF THEORY...
Obtain a trans filter kit for your tranny, purchase anywhere from 2-7 quarts tranny fluid...
Dexron III only and a new gasket for the torque converter drain plug...
If you are like me you will just safely raise the vehicle...
Locate the tranny pan... remove connecting bolts... allow pan to momentarily sag at one corner to drain most of the old fluid...
preferably fluid that is not hot from previous operation
Lift pan down and out the way...
Locate and remove old filter on the bottom of the control valve body...
Remove the 3 phillips head retaining screws...
The old filter should pop right off...
If you wish to drain the torque converter... manualy rotate torque converter/engine until the drain plug is located...
With the "lefty-loosey" theory remove drain plug allowing old fluid to drain into a collection pan...
Correctly re-install the torque converter drain plug with a new washer/sealer...[
not the type of thing you would want to come loose, leaking later]
Install new filter with new o-ring gasket following the directions with filter... [
filter must make good/complete seal or the tranny will not operate correctly]
Re-install pan once it is clean with no grunge on the inside bottom, with new gasket included with the trans filter kit...
Now that the tranny is safely and totaly sealed add "dexron III" any brand style transmission fluid...
If you have chosen to add "TRANS X" or any other style trans treatment, add them before adding the regular "dexron III" transmission fluid...
If using trans treatment most say on the directions "do not overtreat transmission"...
In other words follow the directions for their product...
THE HARD PART
Getting transmission to full with out overfilling...
You could measure how much old fluid you have removed, to know approximately how much new fresh fluid to add...
The main idea is getting the transmission to the full line without overfilling...
As you add/check at some point you need to start/idle the vehicle...
Placing your foot firmly on the brake pedal to hold and lock wheels... shift the gear selector through each of the gears pausing on each one so as to integrate and resuply each gear with fresh fluid...[
with the engine idling...]
When you are most certain tranny is full and no more fluid is needed, test drive the car and recheck and refill as necessary...
PROBLEMS
An overfull tranny will vent/blow out extra fluid, possibly starting a fire... [
hot trans fluid striking hot exaust components...]
An underfull tranny will slip like crazy, if the tranny sits in one spot without properly engaging, add more fluid... [
even if tranny seems full...]
Hope this info helps...
With new fluid/filter your car should shift better, unless the tranny is damaged...
