Old 07-14-2004, 03:48 PM   #1 (permalink)
Date registered: Apr 2004
Help ! Fuel distributor block question
Hi,
Can someone please advice if the
rubber diaphram in the distributor
block is available seperately. If
so where can I buy them from ?
Thanks
j chen is offline   Reply With Quote
Old 07-14-2004, 04:05 PM   #2 (permalink)
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
RE: Help ! Fuel distributor block question
you can get one through an injection specialist but it is a specialist job to fit it, you dont want to see whats in there believe me, get one from the breakers and fit it a lot cheaper
teky is offline   Reply With Quote
Old 07-14-2004, 04:17 PM   #3 (permalink)
Thanks Teky,
Yes I've seen the inside. Got
mine apart. Apparently, only
the diaphram is demaged.
Can you recommend some specialist
where I can get the diaphram ?
Thanks Again
Old 07-14-2004, 04:24 PM   #4 (permalink)
teky's Avatar
Vehicle: chris
bosch is the main agent but the stealership might have a better idea in you area "dont buy it of them unless you won the lotto"[:)] breakers is still the best option and for cost just buy the complete unit
