Old 06-15-2004, 11:41 AM   #1 (permalink)
finland's Avatar
Date registered: Dec 2003
Vehicle: MB 190E 2,6sportline
90´ 2.6 valve lifters
Hello everyone!
Does anyone know when those valve lifters should be changed?
I have now 191000km in my car and in every cold start those lifters are pretty noisy until the oilpressure gets up (2-3s).
So,does anyone have same kind of problem in your mercedes?
What is the normal idle rmp of 2.6?
Thanks!
finland is offline   Reply With Quote
Old 06-15-2004, 01:00 PM   #2 (permalink)
Axel F's Avatar
Date registered: Mar 2004
Vehicle: w201 190D
RE: 90´ 2.6 valve lifters
its normal the (older) valve lifters make a little noise at low oil pressure.
It doesnt do any bad to the engine, it only is a little noisy.
and the chain is holden tight too by something hydaulic. ( a chaintighter does that exist ? :p u know what i mean)
so that can make some noise to al low oil pressure.
are u sure the oil is filled till the 'max'-mark. and dont you have oil leacks ?
maybe u can try ticker oil, somethimes it helps they told me.
http://users.skynet.be/fa782220/voiture/index1.htm
Axel F is offline   Reply With Quote
Old 06-15-2004, 01:24 PM   #3 (permalink)
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
idle rpm is 890 to 990 "finland eh" cold over there if freezing then you want the thinnest oil 0w/40 full synthetic "it dosnt freeze or sludge up" and flows easy ideal for the lifters because they need that pressure asap
teky is offline   Reply With Quote
Old 06-15-2004, 01:34 PM   #4 (permalink)
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280
The lifters are hydraulic, self adjusting, so unless they're totally shot, shouldn't need to be replaced. Are you sure that the sound you hear on start up are the lifters, and not the timing chain slapping the guides? That's the more typical startup noise before oil pressure builds up and is indicative of the need to replace the chain tensioner and/or the chain.
MTI is offline   Reply With Quote
Old 06-15-2004, 02:06 PM   #5 (permalink)
Axel F's Avatar
Vehicle: w201 190D
chain tensioner...
that was the word i needed, thankx MTI[:D]
Old 06-16-2004, 08:09 AM   #6 (permalink)
finland's Avatar
I´ve used 10w40 mineral oil in the summer and 5w40 fully sythetic oil in the winter,sometimes we have -30 celcius degrees in winter but I´m using preheater,it would be too hard start every morning to the engine.I´ve tried in -25 degrees to start without heating and the only problem was the gearbox,shifting was a bit slowly at first but after 5 kilometers it started working
